View Full Version : Think i need more prop
MAMBA2200
10-15-2012, 10:45 AM
So i went out to try the new combo yesterday leopard 3674 1900kv and m445 prop and its a very safe combo with decent speed the first run 42.5mph :wink: i finally broke 40 whooo hooo temps were esc 98 motor 97 ambient of 86 with a water temp of 76 this is a very cool running set up to say the least on the second run which was made back to back of the first run i got 43.2mph both runs were around 4 min before lvc and the temps were nearly identical with esc 97 and motor 99 so im gonna order a m545 to go on it any other suggestions here is a couple vids i made and i was running 4400mah 40c packs
http://www.youtube.com/watch?v=hvOnSWpNEds
http://www.youtube.com/watch?v=oNb5M4nFuPw
chipgibbs
10-15-2012, 03:33 PM
Put a straight edge on the bottom of the vee and see if your strut is parallel and about 3/16" to 1/4" above. Batteries should be not more than 3/4" from the back of the tray.
With his set up and the M545, I get 45 to 48 mph with stock motor and ESC. Also, I'm using a 4200 mah pack not 5000.
Weight matters.
Chip
MAMBA2200
10-15-2012, 04:20 PM
im deff gonna get the m545 for sure that seems to be the sweet spot prop for this boat :flammes-09:
SweetAccord
10-15-2012, 04:21 PM
You need more cowbell...86339
MAMBA2200
10-16-2012, 07:46 PM
Found that my expo settings were not at 100% and now it sounds like the motor is twisting also i had added a bec before my last run checked my eagle tree and it has dropped the amp draw by 20 amps b4 bec 121a after bec 101a i like that:D
Sent from my DROID RAZR using Tapatalk 2
giobors
10-17-2012, 10:46 AM
Weight matters.
Chip
Don't forget to raise up your turn fin:thumbup1:
Giorgio
MAMBA2200
10-17-2012, 03:22 PM
i ordered me a 5s 5000mah 40c pack for my revolt last night that should be ok with the motor esc set-up i use right????:confused2:
I was gonna suggest 5s instead of bigger props. I wouldn't use the m445 to start I would go with x440 x442 or grim 42/55. Any of those props on 5s will get you into the 50's without blowing anything to start
MAMBA2200
10-17-2012, 03:58 PM
thanks dana good info
MAMBA2200
10-26-2012, 04:06 PM
well i bought a m545 prop today from OSE gonna try this prop on 4s and just a good excuse to add another prop to my collection lol:thumbup1:
MAMBA2200
10-26-2012, 04:24 PM
well i havent had time to run the 5s yet but im gonna run it in the next night or 2 i will let you know i was just ordering some stuff for my mystic i just bought and figured i would just go ahead and get one
MAMBA2200
11-07-2012, 12:21 PM
well tried on 5s and the esc took a crap on me so i bought a 180a esc for it hope it will work on 5s at least i will have more amp draw room to play with
Sorry to hear you fried the esc. Which one was it? What prop were you using?
MAMBA2200
11-07-2012, 01:22 PM
it was a seaking 120 it moved about 50 ft and just stopped and that 50 ft was under 1/4 throttle
MAMBA2200
11-07-2012, 01:51 PM
the stock prop 42x55
Hmm that's odd, I'm surprised it blew from that. Doesn't seem over propped really
MAMBA2200
11-07-2012, 02:00 PM
yes i know it didnt smoke or get hot and the eagle tree just said it had a draw of like 32amps it just died would not do anything but there sending me another but i went ahead and bought a 180a anyway
Mike Caruso
11-07-2012, 02:23 PM
I am a new bee but could I run my ESC / MOTOR / BATTRIES with Eagle Tree on a ducted fan deal to check the load? I know it will not be the same as the boat just thinking.
MAMBA2200
11-07-2012, 02:36 PM
yes you can use it on anything as far as i know i use it on all my rc planes boats cars
MAMBA2200
11-09-2012, 08:43 AM
well if anyone can help me out on this took the revolt out yesterday and run it first on 4s with the m545 and i got 42mph then i tried it on 5s now i have changed to the 180a esc also gave it a run and on 5s i got a whopping 41.7 so whats the deal i have a tacon 2 pole motor 3674 1900kv which i paid 36 dollars for brand new in a similar boat and in the revolt its a leopard 3674 4 pole 1900kv which i paid over 80 bucks for new and to be honest the tacon is 10mph faster than this leopard or have i just got a bum motor do i need higher timing on the leopard its at 11.25 on the tacon im at 7 so far im just not impressed with this leopard motor at all but its the first one ive owned if anyone could help with this because with all i have read on this forum my setup on 5s should be haulin and its not i am uploading video that i will post today so you can see the boat in the water and by the way the amp draw on 5s with the m545 was only 83 amps it is a short video cause i was bringing it in to check temps
MAMBA2200
11-09-2012, 09:22 AM
it can be used on stock stuff and is good for high 40's is the stock motor more powerful than the leopard??????
MAMBA2200
11-09-2012, 10:44 AM
would i be better off with a 4074 motor??
To give you an idea, I run a leopard 3674 1700kv in my Titan 29 mono hull, with seaking 120 on 5s2p and x444 prop, and my speeds are right at 50. You should be way faster than me by comparison. The leopard motor is much better than the tacon. Something is not right with your setup. Not sure. Let's hear exactly what you're running. Radio batteries etc...
Btw, you're leopard is a d wind. Timing should be 0-5 degrees tops
MAMBA2200
11-09-2012, 11:32 AM
spektrum radio dx3c t-180 3674 1900kv leopard stock servo and sky lipo 4s 40c and 5s 40c
MAMBA2200
11-09-2012, 11:34 AM
here is the video of the run
http://www.youtube.com/watch?v=ryWg0Jh2a8I
Is your throttle set to reverse?
MAMBA2200
11-09-2012, 11:57 AM
yes
MAMBA2200
11-11-2012, 04:33 PM
Well i tried less prop today used the stock prop and still slow as a snail so i swapped the motor put my 2pole tacon in and it came alive my boat has never been so fast i can say i will probably never buy another leopard motor if they dont run no better than this one does guess i will be buying another motor now:confused:
Maybe you did get a lemon. I own a few leopards and they've all been great. The one tacon I bought fell apart after 5 runs...
Can you exchange your Leo? Did you buy from ose?
MAMBA2200
11-11-2012, 05:11 PM
Yes i got it from ose will he replace it???
You could always ask him.
MAMBA2200
11-11-2012, 06:14 PM
I will e mail him and ask hope he will just so i can renew my leopard faith
Yeah or maybe he could test it or check the motor out. I'm sure if you explain the problem he can help. That thing should be almost out of control on 5s
MAMBA2200
11-11-2012, 07:23 PM
Thats what i thought on 5s it only ran 37mph
bdp1174
11-11-2012, 08:14 PM
I have a proboat radio from a mystic with a hobbywing 180 esc and it is set to normal servo direction on throttle not reversed it calibrates fine when setting throttle endpoints and from what i can tell it looks to be running full throttle.should i reverse the throttle direction and recalibrate like you suggest to others and what difference will that make?
Just want to make sure I am getting full throttle with it like it is now.
MAMBA2200
11-12-2012, 02:08 PM
i will be sending my laim motor back to OSE tomorrow steven said that leopard will fix the motor and return it for me so thank you OSE for your help
