View Full Version : TP 4082 2180kv timing?
kevinpratt823
10-12-2012, 01:49 PM
I have the 4050 series TP 4082 motor, 2180kv, on 4s2p(Impulse 31). I THINK it's a D wind, but haven't confirmed that. Any input on the apprpriate timing for this motor/setup?
10-12-2012, 03:56 PM
If it is a "D" wind, then you will not want much timing, no more than 5*. If it is a "Y"wind it will not be too happy on such low timing.
kevinpratt823
10-12-2012, 05:00 PM
Thanks, I actually already searched and learned about that part. I guess what I should be asking is if it actually is a D wind. The TP site lists a 2050 series 2200kv as a D, but no 2180kv, which is what it says on the label, not sure I should just Aassume they are referring to the 2180.
Make-a-Wake
10-12-2012, 06:10 PM
Maybe the company you bought it from would seem obligated to tell you......... i fail to understand some of these questions when it seems like a simple email or phone call would clear it up. Do the instuctions, or manual, or spec sheet not tell you? I know the wind of every motor i buy since its a spec that allows you to burn it up if its not known. Who/what company did you purchase it from?
martin
10-12-2012, 06:43 PM
Kershaw Designs sell this very motor, im sure they could give info your looking for.
kevinpratt823
10-12-2012, 11:39 PM
I bought it from Steve at OSE here. Picked it up at his shop, but there was no paperwork with it, and honestly, it didn't occur to me to find out at the time. I am still new to boats, and with all my brushless(Tekin sensored) cars timing is not as big of a thing. I figured I'd put it out here because I know several were sold on the forum.
785boats
10-13-2012, 07:34 AM
Kevin.
I run a couple of those motors . They are definitely a 'D' wind. Low timing, like Fluid said.
Cheers.
Paul.
kevinpratt823
10-13-2012, 07:56 AM
Thank you Paul.
cacofonix
10-13-2012, 04:05 PM
hello
i ran all my Leopard from 15 to 22°
leopard really like timing
herve
Mel279
10-27-2012, 08:34 PM
hi
I've two set of those motors in my HPR115 triple xXx, its a 8D wind motor if Im not mistaken. Im running 5s with x850/3 props(50mm)
hi
x850?
What prop is this?
KartRacer
10-30-2012, 09:18 PM
I'm running leopard 4092, read that it should be low timing I have it set at 3.5.
iamandrew
10-30-2012, 09:45 PM
Yeah id recommend low timings as well
I was using a 4074 at 15 and then dropped it to 7 and found it ran cooler, and same speeds, so obviously it didnt make it any better
Mel279
11-02-2012, 09:41 AM
x850?
What prop is this?
this prop http://www.ebay.com/itm/VXP-X850-3-CNC-Alloy-Prop-EP-Nitro-Non-Lifting-Propeller-50mm-1-8p-3-16-4-76mm-/170884944861?pt=US_Character_Radio_Control_Toys&hash=item27c98953dd
