View Full Version : UL-1 graphics wrap with 3M
96XP
10-11-2012, 04:08 AM
I used to be an air brusher and as I don't have time anymore I designed and did this test on my UL-1 and wrapped it with 3M media.
As the speed of these boats aren't too dramatic, I use removable Scotch tape to seal the cowl on all 4's and the graphics have stayed in place.
Never had a blow off, never had a leak, however on a larger/faster boat, I would clear coat over it with PPG in order to use a thicker tape.
I'll be designing something less aggressive yet still interesting and racy once I get the new boat in.
86163
86160
86161
86162
siberianhusky
10-11-2012, 06:41 AM
I really like that!
Jersey Crewmax
10-11-2012, 06:55 AM
You should consider offering that as a service. A lower cost alternative to having a boat painted.
rotax583
10-11-2012, 07:58 AM
I want one 2????
96XP
10-11-2012, 04:14 PM
Thanks for the comments and I have no plan on marketing them at the moment as I'm a fairly busy all the time with larger projects, but, you never know as I might be able to slip a couple in from time to time providing I have what is required (templates).
It is much less expensive than paint, and way less time holding up the machine/boat for cosmetics and the reason I went this route. Took just an hour or so to apply. I have the same on all my jet skis, above and below the water line and they have held up for years in sun, water, even resist gasoline spills. (Haven't tried it with nitro fuel yet but should be ok)
I have clear coated over graphics in the past, so deep in fact that I could cut/polish and feather the edge to invisible so that you couldn't tell where it met the background. (show applications)
The graphics can't be made without outlines, meaning, it required templates taken from all the body panels along with registration marks and reference images to get it all lined up in the computer. That's because I like text or designs to flow into each other.
I use green painters tape for templates, sometimes a couple layers so when I pull them off to stick them onto flat paper for scanning, they don't distort. Not a big issue because the final print is flexible anyways, so can be 'shaped' onto the surface.
So to contradict myself, if there is a large scale boat builder in need of something very unique and time is of the essence, I may be able to help out. Just pm me with your ideas and we can go from there.
86170
86171
86172
dougspaint
10-11-2012, 04:40 PM
I would like to see some of your airbrush work if you have some pics of it. Always enjoy seeing what other people come up with.
96XP
10-11-2012, 05:24 PM
I'd have to dig through discs as I haven't brushed in years (but still have some brushes just in case), however did a lot of muraling, faux finish and custom paint using the old Radiance II line... pearls, ghost, polyester metal flake, and so on. Did lots of cutting (frisket) Then one day, long ago, I had some print work done and tried clearing over it. That was in the day when solvent printers were just coming out, so the quality wasn't optimized as it is now.
That said, and not knocking air brush art, there are times when it just has to be done with paint. Been there bro and still appreciate it ;)
On a side note, I recall this huge contraption the industry came out with years back, became the talk with the brushers. It was this setup of air brushes on a giant upright gantry system and paint lines, and they were muraling the sides of tractor trailers through computer input. Didn't last as the other machines came to the front and media was being perfected and manufactured.
86173
monojeff
10-12-2012, 03:32 AM
Is that your website??
Nice work on the UL-1
Love to see people doing different stuff.
monojeff
10-12-2012, 03:36 AM
Just looked at the site more and now realize it is your site you have some awesome stuff!
Very nice work, your an inspiration to someone like me who also enjoys many of the same things.
96XP
10-12-2012, 04:17 AM
Just checked out your link. Right on.
What sometimes starts out as a hobby can easily turn into a passion.
Hence, "It's not a job, it's my passion". Lol
Have you got a printer?
monojeff
10-12-2012, 11:16 AM
I do not personally have a printer but work at a sign shop that does.
Been doing graphics for over 10 years and working with vinyl for over 5.
You can see some of the stuff I have done for boats here:
http://forums.offshoreelectrics.com/showthread.php?19600-Decals-amp-Wraps-Any-and-All
http://forums.offshoreelectrics.com/showthread.php?20431-Custom-Windshields
My website has been down for a while was in process of moving it to a different server and just have not had time to rework and update things.
Grimracer
10-12-2012, 03:26 PM
Over due and WELL DONE!
Great job!
Grim
Brushless55
10-12-2012, 08:36 PM
Bad to the bone!!
what does something like this cost?
thanks
96XP
10-13-2012, 08:15 AM
Thanks for the posts as I hope that FE boating gives me as long and great a joy as doing the graphics.
Some are asking, and honestly didn't intend on selling the graphics as I was just tinkering with the two UL-1's I have here. (his and hers)
She doesn't like the kit I designed for her boat and wants me to do something a bit more gentle (ya, right, Lol)
So I'm posting the other kit and a link to see it in a larger format as the images I post here are reduced and compressed, thus lack the details I like incorporating.
I'll give this kits away if someone covers the postage as it won't fit in a flat envelope and has to be rolled. (first one who PM's me gets it)
There isn't a cut file made for it yet, so cutting will have to be done by hand if you have the coordination.
*This kit would go best on a red boat. If no one has red, but has yellow, I can make a yellow version.
It'll be printed on 3M 'wrap' media. This is the highest quality in a thin easy to contour media currently available.
You will then only need removable Scotch tape to seal the boat up and the graphics will stay perfectly in place as we have been doing it this way for months.
*Michael Grimracer Zaborowski
AquaCraft Boat Designer
Love your work. Pick whichever kit (if you like) and I'll send it :)
Here is a close-up link:
http://www.http://worldclasswraps.com/UL-1-GRAPHICS.html (http://worldclasswraps.com/UL-1-GRAPHICS.html)
86233
Raydee
10-13-2012, 08:22 AM
Man I wish I owned a UL-1 now :)
Great work, I alway's liked te wraps on the boats.
Brushless55
10-13-2012, 11:32 AM
Nice site man!
96XP
10-13-2012, 02:27 PM
Brushless55 has taken the offer.
Will send it out this coming week.
(sent you a pm for mailing info)
96XP
10-13-2012, 08:49 PM
Hey Todd, just finished the print.
Number layer was turned off on the first run, so printed off a second with them in the image. Doh...:doh:
Also swapped for blue as it looked better.
86272
86273
Brushless55
10-13-2012, 11:50 PM
Awesome!
Still good on a red ?
Grimracer
10-15-2012, 02:10 PM
86233
Really! SWEET.. give me some time to look around at your work!
COOL!
Grim
96XP
10-15-2012, 07:50 PM
COOL!
Grim
You bet ;)
@Todd
Shipped the graphics today Expedited Parcel.
Postage was $18.24
I'll send you tracking info. :)
Brushless55
10-16-2012, 12:53 AM
money sent :biggrin:
96XP
10-16-2012, 08:19 AM
86372
Link to larger detailed preview coming soon.
Grimracer
10-16-2012, 11:32 AM
86372
Dude.. your work is SO FAR AHEAD OF ANYTHING I HAVE SEEN BEFORE i am having a hard time visualizing what I might want.
Can you whip together something (the darker the theme the better) with some Yellow Black and White and not make it look like a dirty banana.. (that what happens when I try this lol).
I see so much I like my brain is in overload! LOL
Also.. here is what I see guys. This dude is SO passionate about his art its not a matter need.. Its a matter or PASSION!
Fantastic work!
Grim
96XP
10-16-2012, 04:39 PM
@Grim
I have a couple ideas already and go by feel most of the time, just need a few short days to get it setup.
If you have a few other elements in mind, let me know, as it's sometimes hard to get into the right groove when the sky is the limit.
Grimracer
10-16-2012, 04:53 PM
@Grim
I am a HUGE Megadeath fan! :rockon2:
I have no idea now you even begin running with an idea. You are LIGHT YEARS ahead of what I have seen..
Grim
96XP
10-16-2012, 08:11 PM
Link to preview details from the Enforcer graphics:
http://worldclasswraps.com/UL-1-GRAPHICS-ENFORCER.html
96XP
10-17-2012, 09:26 AM
Symphony Of Destruction:bash::flammes-09:
Sharp details here:
http://worldclasswraps.com/UL-1-GRAPHICS-Symphony_Of_Destruction.html
86587
Brushless55
10-17-2012, 09:33 AM
Crazy awesome skills!
SirBudman32
10-17-2012, 09:39 AM
Ok I want this one. Love Mega Death.
Sharp details here:
86587
Grimracer
10-17-2012, 11:24 AM
Sharp details here:
86587
BINGO.. give me a Dave Hester..........yeeeeeeeeeeeppppppppppppp!
Grim
96XP
10-18-2012, 07:40 AM
Send me a PM with mailing instructions. :rockon2:
Side note, just installed a new print head today, so will take a couple days to tweak everything before I fire up the machine.
Grim
96XP
10-18-2012, 10:27 AM
Revision on the design.
(Made a version 2 with knife edging and smoke coming from bullet holes.)
Question is, which one looks best?
http://worldclasswraps.com/UL-1/UL-1%20MEGADETH%20edit2.jpg
http://www.worldclasswraps.com/UL-1/UL-1%20MEGADETH%20edit2.jpg
Brushless55
10-18-2012, 11:57 AM
That is killer!
rotax583
10-18-2012, 01:56 PM
how much for the enforcer setup just like you have on the pic I want it for my ul-1 thanx awesome
rotax583
10-18-2012, 02:00 PM
in the yellow version sorry.
RandyatBBY
10-19-2012, 05:29 PM
Man your work is great. Thank you for the tip on making templates. I can see I will be looking at your sight for a long time.
monojeff
10-19-2012, 05:36 PM
Guys this is not a FOR SALE AD if you want to get in touch with him about purchasing 1 of his designs/wraps then PM him and discuss details there otherwise I say lets keep this thread open for what it is to show off the awesome designs he produces!
If he is going to start selling them then I would assume we will see it in the Manufacturing section when that time comes if he chooses to start offering them to everyone.......
Brushless55
10-24-2012, 08:37 PM
got the wrap bro and I have to say there is no one I know or seen with your skills!
awesome job :rockon2:
96XP
10-26-2012, 07:26 AM
Just getting back in town and resettled at the computer. Sorry I haven't gotten to a few PMs that are growing in my mail box yet, but will tomorrow after some sleep.
USB3 hub down (heat's a killer).....running on backup USB2 until the new one arrives on 29th, so drives are moving painfully slow as well for cache. If you've ever been there with large files and disc drives, you'll know what a literal drag it can be. Arg.
Off topic, it's just about winter here now and I have LiPos still charged. Wonder if it's safe to take the boat into the cold water (42f) to run them down for storage. Any advice appreciated.
Grimracer
10-26-2012, 09:00 AM
Its OK to run the packs.. just dont run them cold... Make sure they are 70hs or so before you run them.
Grim
RandyatBBY
10-26-2012, 12:24 PM
You also want them to be in the 50% to 60% range for storage. I use RC cars and a EOS to get mine to that point.
96XP
11-01-2012, 09:52 PM
Thanks guys.
Q: What is the reason to not run them below 70 degrees F?
Q: What happens if you just leave them full to discharge on their own over time?
Grimracer
11-12-2012, 02:23 PM
Got the goods.. WOW.. the dudes here at work are like... SCHWEET!
Im going to do up a new UL for this!
Hope to have it done soon!
THANK YOU 96XP!
Grim
RandyatBBY
11-12-2012, 02:49 PM
Thanks guys.
They will run a little slower no harm that I know of.
It makes them have a little shorter life span and they do not run as crisp.
shrive81
11-12-2012, 04:40 PM
Ok maybe I missed it but what is the price for a ul-1 wrap
monojeff
11-13-2012, 08:42 PM
Here is his sale thread
http://forums.offshoreelectrics.com/showthread.php?38389-Custom-Highly-detailed-graphics-wraps&p=466592#post466592
This isn't the section to ask about pricing info.
Either post in his thread or pm him....
dana
11-13-2012, 09:15 PM
Looks awesome, but it's spelled "megadeth".
dana
11-13-2012, 09:20 PM
Although I suppose you spelled it that way for selling...
Stinger9D9
11-13-2012, 11:39 PM
It sure is. D'oh!
