View Full Version : What do you set you power supply voltage to?
WhatRLaws4
10-04-2012, 05:42 PM
I just got my 540w 30amp power supply today. It has an adjustable voltage from 12-18volts. For now, I will only be running a single 200w 10amp charger to charge my 4s 5000mah lipos. What should I set the voltage to?
LiPo Power
10-04-2012, 11:47 PM
Check your charger first. It will tell you what input voltage it will take...
WhatRLaws4
10-05-2012, 01:46 PM
It says 11-18 volts. Should I crank it up to the max? Maybe just halfway?
LiPo Power
10-05-2012, 02:48 PM
Chargers need top rated voltage to give you the max
rated charging performance in most cases.
Set at 15 and off you go...
