Revolt30
10-01-2012, 05:51 PM
Whats he most battery voltage you can use on the Revolt 30? Using 2-7.4(14.8V) 5000 mah 50C now.Can you use more then 14.8V or will it just burn things up?
MAMBA2200
10-02-2012, 09:03 AM
if you have the stock esc here are the specs for it
SPECS:
Length: 3.25" (83mm), Width: 1.5" (38mm), Height: 0.3125" (17mm), Weight: 3.8oz (109g)
Wire Gauge: 14 gauge
Max Output Power: 720 watts
On-Resistance: 0.003 ohms
Low Voltage Cutoff: 11.63V, Thermal Cutoff: 230 degrees F (110 degrees C)
Stutter Bump Voltage: 12V
Operating Frequency: 8KHz
BEC: 5.2V/2A
Timing Angle: 10 degrees
Battery Connectors: Male Deans Ultra Plug Connectors (2)
Motor Connectors: 4mm Gold-Plated Bullet Connectors (3)
Input Voltage: 12-14 NiMh 4 Cell Lipo (8-20V inout w/o BEC)
Output Current: 60V Continuous Maximum with a 72A Surge Maximum rating.
