View Full Version : Will the stock motor
MAMBA2200
09-29-2012, 09:25 AM
well will the stock motor handle 6s being a 1800kv i think it should but wanted to get opinions thanks :confused2:
5s yes, 6s? Maybe for a short time, but it will eventually destroy it. Could be 30 seconds, could be 3 runs. Bad idea tho
MAMBA2200
09-29-2012, 09:38 AM
hhhhmmmmm ok thanks guess i will just upgrade it any suggestions?
Of course I could be totally wrong. I would go for something in the 1500 kv range
MAMBA2200
09-29-2012, 10:11 AM
i used to run a 2200 castle in my spartan on 6s and ive seen many people use a 1800 leopard in the spartan but im still learning this kv and cell business in boats :doh:
Make-a-Wake
09-29-2012, 10:21 AM
Why higher voltage? Why not just prop up on the 4s setup? An x640 or even an m445 may really liven it up.
MAMBA2200
09-29-2012, 10:39 AM
well i went back to test the 45x68 and did not gain a bit of speed just wanted to jump it up some and see what happened
Make-a-Wake
09-29-2012, 11:02 AM
You're using a high lift prop on a Vee hull that wants forward propulsion....................
MAMBA2200
09-29-2012, 03:20 PM
thats why im thinking 6s lol:Peace_Sign:
Make-a-Wake
09-29-2012, 03:22 PM
So running an extreme voltage, on a smallish motor with a lifting prop designed for a Hydro or rigger is the answer................:doh:
MAMBA2200
09-29-2012, 03:27 PM
thats what im asking should i go with a different motor for that voltage cause im thinking i got a dud motor or would you suggest a different prop was thinking of a prather 220 what is your opinion
