View Full Version : Good CG range
MR2NR
09-27-2012, 09:55 PM
So I've about got the boat together and started with a bare hull. What is the best CG on these? First Hydro coming from mono. I know that 2/3ds toward the rear is good for monos but thinking Hydros want more in the center if not forward a hair for good sponsoon tracking. :). Also I would like to see weights of these and asking anyone with heavily modded boats what your wet weight is. (fully loaded with batteries.)
I'm sitting at 5 Ibs. 3oz. right now. but need to finish some coolant line and S+B the prop
lenny
09-27-2012, 10:05 PM
Hi.:tiphat:
Have any pictures of your boat and setup inside of the hull ?
How big is the boat and on what cells will you be running ?
MR2NR
09-28-2012, 12:14 PM
Hi.:tiphat:
lol well It's a normal RTR UL-1 Dont really know if there is much of a variation size wise from revisions. I'll be running 4s. As soon as I get the cooling tubing done Ill post some pics.
MR2NR
09-29-2012, 07:09 PM
Here's some pics...
85347
85348
I also had to repair the left sponsoon and it was cracked in a few spots so i just sanded things down and epoxied some carbon on it.
85349
Same with the Transom.
85350
85351
I am running two pickups as the tiny rudder one doesn't sit well with my motor size.
...and i know I am running too small of battery connections but I had a ton left over from the cars and when I am a little more better with finances I will upgrade to 5.5's, kinda why I screwed up the soldering job on the Y harness :)
h2o 1
09-30-2012, 12:55 PM
COG on this hull should be an inch and a half to three inches behind the sponsons Matt.
Run the batteries as far forward as possible. What motor is in there?
lenny
09-30-2012, 01:30 PM
I think it is a 3674 2200kv.
But not sure on that.
He said it was stock setup.:noidea:
MR2NR
10-03-2012, 10:17 AM
Stock Hull but all the internals is aftermarket except the servo. Leopard 3674 2200K is correct. Using Gens Ace 2200 60c Batts 4S. They are in the pic :) Shoved as far forward and outboard as I have seen :). But ya run time will be around 15 min I'm guessing.
G-UNIT
10-03-2012, 04:38 PM
Just budding in here, I have the same set up with that motor running 4s 5000mah 40c-50c burst
with a m445 s&b, running in the 50 range but I don't belive you will get 15 min run time out of it, more like 4-5 min, but anyway run it for a few laps and check temps.
jmo, have fun.
MR2NR
10-03-2012, 06:27 PM
How much time are yours getting? If things are that bad Ill just run 2s for fun and 4s to race. :) I also have some hardcase 40'c but cant get them in the hole :).
G-UNIT
10-04-2012, 08:20 AM
Like I said I'm getting about 4-5 min on 4s thats 2x2s to make 4s, I not sure but that motor won't perform on a single 2s.
I could be wrong, just never ran it or tryed it on 2s and only 7.4 volts it will be slow.
Everything I read in this site says most all fe boats run between 4-6 min.
if your getting 15 min run time thats great, but hard to believe on 2200 mah batterys.
MR2NR
10-04-2012, 11:41 AM
Well on my mono I can get 30 min with 5000mahs so I was just halving it :). Ill bet you are right though with a hydro and bigger prop. I really like how these batts. fit though. I was thinking I could just by another pair and put them in parallel and double the Mah but I hate the way you have to splice solder. Would be cool if they made a 5.5 Y or T bullet or is there a better way ? Maybe stick a 5.5 in a 8 solder hole.
G-UNIT
10-04-2012, 11:50 AM
Are you running in series or paralelle ? spelling, you know what I mean.
Even on my impulse, still only getting around 4-5 min on 5000mah and when recharging them i'm putting 3800-4000mah back in.
you should leave about 20% of charge in the batterys.
What kind of mono?
MR2NR
10-04-2012, 03:03 PM
Both if I get two more packs. Parallel batts. Series to the ESC. so I would be at 4400mah with four 2200mah batts. I have 2 on board voltage meters on each batt. so I know where Ill be I heard that the ESC Im using isn't very reliable with voltage cutoffs so I am not relying on it :).
I mainly did this because i wanted the batts. to be as far outboard as possible and the hull came with a huge hole in the front so why cut it up any more :).
Dana I am referring to the Jet Stream in my avatar. It wasn't very fast though so Im taking that into account that as well.
I'm thinking now I will need the extra batts but of course I bought the last two HP had lol. I prob have the lightest UL-1 though right now lol. Might run it one or two passes and see where I'm at.
MR2NR
08-18-2013, 05:18 PM
Well after about a year I finally got the S+B prop back as I was lazy and really hadnt had much time lately to go get it. But the boat really didnt want to go like it should. I could get it to plane but barely as I'd say it's prob running 15-20 MPH. I'm afraid my prop is not thin enough. Does OSE sell a thin enough 40 57 prop for the UL-1 S+B'd from them?
MR2NR
08-18-2013, 08:44 PM
Just went out again and stuck the strut down and got her to pop out super easy and she did the basic 25-30mph ya! Now I need to up the battery's.
