benjijames
09-25-2012, 09:18 AM
Hi,
I have a seaking 180 a esc on my miss geico and I have a problem of discharge. When I start to ride the boat on 5S or 6S, every cells have a tension of 4,20 v. Until 3,70 V, the cells discharge at the same rate.
But when the voltage reaches 3,70 V, the voltage of the battery on the right side goes down suddenly, the battery on the right side gets warm and sometimes swells. For example on 2S, one cell is 3,20 v and the other one 3,40 volt. The balance disappears. No problem with the battery on the left side of the boat. I have tried to change the battery (2S and 3S) and even the motor, but I always encounter the same problem. So I definitely need to stop the boat at 3,70 v, otherwise I kill the battery on the right side. From what I know, I should be able to ride until 3,30 volt (recommended cut-off level )
Do you think my esc has a problem ? I power my receptor with a separated battery pack.
Anyone has a solution to my problem ? Thanks a lot.
