View Full Version : Got my revolt
MAMBA2200
09-21-2012, 09:14 AM
well i got my revolt yesterday overall i am very happy here is a few things i noticed
-all the gear on the back is way loose (no biggy)
-i got no owners manual or stickers:confused2:
-when i turn the prop the motor wiggles back and forth:doh:
-there was nothing holding the hatch on so its scratched allot around the hatch hole (again no prob)
- i do have lock nuts on all hardware thats a plus
it almost seems like i got a boat that someone else had returned but i can fix all that is needed here is a video of the motor wobble
http://www.youtube.com/watch?v=OzEmbuHJ-zs
Grimracer
09-21-2012, 09:23 AM
Hum.. No manual.. I bettter give you the contact info to Product Support.
Call em and see if they can get you setup.
Grim
Hobby Services
3002 N. Apollo Drive, Suite 1
Champaign, Illinois 61822
Attn: Service Department
Phone: (217) 398-0007 9:00 am - 5:00 pm Central Time M-F
E-mail: hobbyservices@hobbico.com
Also.. here
http://manuals.hobbico.com/aqu/aqub24-25-manual.pdf
MAMBA2200
09-21-2012, 09:48 AM
thanks grim i have contacted omni thats where i got it from but so far have had no responce will give them a chance to make it right first :beerchug:
bruceisla
09-21-2012, 10:43 AM
You appear to have either a bad coupler or a bent motor shaft. Try removing the coupler and spinning the motor shaft to see which is bad. It's possible the coupler is cross threaded. Video is a bit shaky and too short to look closely.
MAMBA2200
09-21-2012, 04:28 PM
well they are sending me the missing item and i think the wobble is flex shaft which i have already got the upgraded shaft so all is good i can fix the rest
MAMBA2200
09-22-2012, 09:17 AM
got my seaking 120a V2 and 150a eagle tree time to start the build as everything will be here today 8489684897
Mike Caruso
09-22-2012, 10:12 AM
Check out my gallery I mounted the ET to balance the boat out side to side. Aeromarine flex collet and Hughey shaft is what I am running trouble free. Stock prop runs good 45x68 pulls more amps but adds mph.
Have fun man.
Mike
MAMBA2200
09-24-2012, 09:26 AM
well i got the rest of my parts and it was the flex shaft bent i dont see how they crammed it in there gonna call aquacraft today and see if they will send me another because this one is crap but i have the upgraded cable installed and all is well85043
bruceisla
09-24-2012, 10:15 AM
Well .... you may be expecting a bit much. Flex cables flex .... that doesn't look like a kink (sharp bend).
MAMBA2200
09-24-2012, 11:14 AM
this i know when i pulled the old one out it had like a 45 degree bend on the end of the cable
stadiumyamaha
09-24-2012, 11:28 AM
I wouldn't bother getting them to replace the stock flex. They are so suspect that you don't want to risk losing a good prop. Many times they fail in the first couple of minutes. Jmo
MAMBA2200
09-24-2012, 11:57 AM
i hear ya think i will take that advise:beerchug:
MAMBA2200
09-25-2012, 09:49 AM
well its all done and ready for its first run here is some final pics85125851268512785128:beerchug:
ktodd
09-25-2012, 05:39 PM
Looks great! Looks thirsty for water :laugh: Let us know how it runs :smile:
MAMBA2200
09-25-2012, 05:42 PM
will do im off thursday thats when the maiden voyage will be and i will video it and post it up :thumbup:
Tom899
09-27-2012, 06:39 AM
Looks great! And good luck on your maiden voyage! Very exciting! If you get a minute, I'm most interested in how the Seaking ESC works out for you? Are you starting out with the timing at 11.5? What do you have the LVC set at? I guess I'm most interested in what type of warning you get when your batteries start to run down. With the stock ESC there's a feature called "Studder Bump" but basically if this happens you really have no time to bring it in and you get stranded. I have taken measures to overcome this by just running for a few minutes and bringing it in while it's still running fast, but it sure would be nice to maximize my running time. Anyway, sorry for being long winded, just really interested in how well your ESC works and what kind of warning you get.
Thanks,
Tom
MAMBA2200
09-27-2012, 09:15 AM
Ok will do running it today will let u know
Sent from my DROID RAZR using Tapatalk 2
MAMBA2200
09-27-2012, 05:10 PM
Heading to the water for maiden run will post video in the morning
MAMBA2200
09-27-2012, 06:57 PM
Have a question on the first run the batt wires got really hot and melted where the wire plugs into the batt i am running 5200mah 65c stock prop had a max amp of 84.4 amps do i need to put bigger wire on them its same size as esc no binding in cable ran great just batt wire problem is only problem please give me opinions thanks
Grimracer
09-28-2012, 08:45 AM
Hardpacks?
If so the 4mm bullets leading to the pack are just not going to cut it.
Grim
MAMBA2200
09-28-2012, 08:56 AM
Ok then just use a solder connected packs ? what if i soldered them
hobby_man
09-28-2012, 10:23 AM
I ran the boat stock, the stock speed control is rated for 50 amp continious, after buring out the motor/speed control in mine 3X they gave my my money back
bruceisla
09-28-2012, 10:31 AM
When you get a chance, post some pics of the melt-down so we can see exactly where the heat was excessive.
traeside
09-28-2012, 10:35 AM
also how long are your wires? keep them as short as you can and put some 5.5MM conectors on there.
MAMBA2200
09-28-2012, 11:55 AM
the heat was right where the wire went into the battery
bruceisla
09-28-2012, 12:18 PM
So .... right here at the tip of the arrow .... correct ??
MAMBA2200
09-28-2012, 12:53 PM
yes but the batts are the kind with the 4mm connector prob just too much amp draw on those connectors
MAMBA2200
10-01-2012, 01:08 PM
figured i would sharpen and polish it up hope you like 8550885509
