View Full Version : revolt performance
4343
09-18-2012, 07:10 PM
hi, does the revolt at all chine walk like the spartan on stright out runs??
Mike Caruso
09-18-2012, 08:01 PM
I never had your boat but Re Volt will chine walk with the optional Grim 45x68 prop not bad at all. Runs fine with the stock prop all I have done to mine is lower the right rear trim tab level with the bottom of the boat it could use a little more with the big prop. I also rubbed 3m pad on the bottom of the hull and rounded off the rubber bottom and sharpened EVERYTHING !!!!!!! :buttrock:
You will love the boat if you have water for it. Not an Ocean racer but mine loves 2" chop and a 10 mph wind blowing around.
Have fun I hope this helps.
Mike
4343
09-19-2012, 12:05 AM
Mike , are you saying it chines with 45x68 prop? what about the included 42x55 prop?
dana
09-19-2012, 12:15 AM
It's gonna chine walk like any other v hull at certain points. Once you get them up to certain speeds they all do this. Some can handle more speed than others before it starts.
TheJANG
09-19-2012, 01:57 AM
Mine sometimes walks with the 45x68, sometimes not, depending upon trim. Never had it happen with the stock prop.
Mike Caruso
09-19-2012, 06:57 AM
Yes just like he said.
Tom899
10-02-2012, 08:49 PM
I'm running the 45x68 prop. I had chine walk until I removed the foam pad and stacked the batteries on top of each other instead of side by side. I can now run the batteries all the way back with very minimal chine walk. Maybe I got lucky with my adjustments and just fumbled upon the right combination. Whatever it is I'm leaving it for now. If there's a light chop I'm running 42. I wouldn't mind getting a few more mph but not sure how yet. I really like the boat and hardware. Plus, everyones feedback in this forum helps a great deal.
Jersey Crewmax
10-03-2012, 07:51 AM
I'm going to try mine out without the foam to see how it runs. I think it makes more sense since it will put the weight down a little further
