View Full Version : proboat mystic 29 question
larz001
09-15-2012, 08:18 AM
hi folks i was just currious if a mystic would hold 2-14.8v 5000mah packs for double the runtime
Garrett
09-15-2012, 01:00 PM
Not sure, I have a little trouble getting my 11.1V 5000mah packs in there, but itd be something to take the hull to the hobbyshop and try to fit it in there, some hobbyshop guys will let you do that.
Make-a-Wake
09-15-2012, 01:31 PM
Find the measurements of the ones you're considering and measure the space you have.
lenny
09-15-2012, 01:59 PM
Hi,
tunnelvision is running two 3s cells for 6s in his Geico,
But not sure what mah they are and what mods he did to the setup.
larz001
09-15-2012, 04:22 PM
i'll have to wait untill i get the boat next week
the guy im getting it fron says he had no trouble getting 2x 11.1 packs into it, i have a friend on this forum that lives close to me and he already said i could try a couple of his 14.8 packs to see if they will fit, his concern is that the extra weight would adversley affect the handling of the hull does anyone else have any advice on this?
also would it strain the electronics if they do fit?
yfzbrad
09-16-2012, 09:59 AM
4000 mah 4s packs fit soft packs. have done it but you have to drop the batt trays... If you run two 4s packs in parallel everything will be fine...and the extra weight up front in my mystic helps smooth it out
larz001
09-17-2012, 10:33 PM
thanks for the info
