View Full Version : nylon breakaway screw for rudder - where to buy
bob_t
09-14-2012, 09:06 PM
I've seen several MG29's with a nylon breakaway screw in the lower rudder bolt hole. I would like to change mine to that setup. I know it is a simple question, but where do you buy that screw. The only 3mm nylon screws I found were too short.
Thanks,
Bob
de-pro
09-15-2012, 12:08 PM
I get mine from ebay. Any size you need:
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=m3+nylon+screw&_sacat=0
bruceisla
09-15-2012, 12:12 PM
http://www.kintecracing.com/Nuts___Bolts.html
near the bottom of page. Probably not cost effective unless you need some more stuff.
bob_t
09-16-2012, 03:49 PM
Thanks!
Bob
srislash
09-20-2012, 08:55 AM
I use a 4mm one.I found the 3mm allows the rudder to move a bit.I'm probably a little late here,Sorry
bob_t
09-20-2012, 09:59 PM
No problem, thanks for the input. I saw on e-bay (from post above) you can get a packet of 100 relatively cheap, so I will have a lifetime's supply :biggrin:
