View Full Version : Tim's Tear Into Build
damfurst
09-08-2012, 06:46 PM
Building a NQD Tear Into Jet Boat for the son of a friend. Started by gutting all electronics out of boat. Then poured in some 2 part foam into bow. Did bearing mod to front of drive. Sharpened impeller and greased impeller shaft with Gorilla Snawt. Drilled hole in side of Stator and shoe goo'd water pickup in.
8411584116841178411884119
damfurst
09-15-2012, 05:00 PM
Been working some more on the build for the son of a friend. I had an extra Mystery 3000kv outrunner motor so decided to use that to power it. Soldered connectors on and made a cooling plate out of copper plate and tube. Installed both motor and cooling plate by first drilling out mounting holes on drive. I have found it easier to mount the motor by doing this. Soldered ends on a Hobby King 60a marine esc and velcro'd to inside of hull. Hooked some of the cooling lines to esc and then motor cooling plate. Moved onto servo. Using a traxxas waterproof servo I had from a previous build. Used a piece of cut angled aluminum for the mount and a zip tie to fasten to the servo mount. Mount was shoe goo'd to the bottom of the hull. Should be testing it soon before sending it off.
8458484585845878458884589
