View Full Version : Impulse 31 Deep-V BL RTR V2
Nutbar
09-07-2012, 04:15 PM
I just noticed that there is a VERSION TWO of the Impulse 31 that looks like it is strikingly similar to the Traxxas Spartan. http://www.horizonhobby.com/products/impulse-31-deep-v-bl-rtr-v2-PRB4250B#t1
I was wondering if anyone had any reviews of it yet, and/or how it compares to the Spartan? From what I can tell, it's a bit smaller, has a fiberglass hull, and is a little cheaper. What does everyone think?
Make-a-Wake
09-08-2012, 11:42 AM
It has a different motor and a new 80a speedo, bout time they went up on the speedo as the original stock motor, and this one I imagine, can take a good amouont of prop. Now folks can get into the low 40's on the stock setup with just a prop upgrade.
Diesel6401
09-08-2012, 11:49 AM
Spartan is a over-priced hunk of plastic. Save your money and get the impulse. Built by a racer and not some advertising company that was more worried about the stickers and the name rather than its performance.
S3 iPhone killer via Tapatalk
gtrcguru
09-08-2012, 12:53 PM
never owned a spartan but i do own an impulse v1 and it is a fast and stable boat when set up right.
Kraemer
09-08-2012, 04:02 PM
I hope they fix all the leaking problems in the new version. My Impulse 31 was leaking through the drain plug and all the screws from the trim tabs out of the box
Still waiting for Horizon to get back to me in terms of warranty.
Hi Guys!
Did anyone allready hear something (bad-good) about the new "animal" of the Proboat, I mean the new Impulse 31 V2?
Thanks,Niky.
mannytx1
11-01-2012, 02:44 PM
:flammes-09:8776287763877648776587766
Diameter reduced, back- cuts, balancing and detongueing , sharpening, 42x55 -- 40x55
connector 4mm Gold
cooling hose 1/4x.170 O.DxI.D
servo does not work
esc does not work for high volt cutoff and cutoff type ldle, (can not be programmed with programming card)
not recommend this boat
after 10 day, proboat not have parts for warranty, out of stock
incredible disservice
Hi Guys,
does it mean mannytx1, that you run your IM on 6s?
And if you did, please tell us how it seems?
Is it the truth what they say at Peoboat that the New IM is copatible with 6s?
Thanks.
mannytx1
11-06-2012, 03:22 PM
8811088111Problems begin:help:
servo does not work
mannytx1
01-14-2013, 07:05 PM
919339193491935
Impulse 31 v2 improved
The problem was the color. I change the color and no more problems LOL…..
-Battery 5S 4000 mAh 40C
-Propeller (Battery 5S, motor timing LOW)
42x55 45.4 mph
M445 46.3 mph
42x55 the tongue removed 47.2 mph (timing high 8% more speed and Amp)
M445 reduced to 42mm diameter 50.8 mph (timing high 8% more speed and Amp)
-Cooling hose 1/4x .170 O.DxI.D
-Connector 4mm Gold battery
-ESC front, more weight to the front, batteries more near the CG
-CG 30 % 8” ¾ or 9”
-Improves cooling system
-The antenna of de other side
-Reinforcement of the hull and hatch cover with fiberglass and resin
-Modify the original turn fins
- flex shaft (Miss Geico)
-Adjustable trim tabs
-Homemade bushing
-Hatch lock
-The stock 1800KV motor and ESC 80 Amp (only 5s)
-weight of the boat 4 ½ pounds without battery, with battery 5 ¼ pounds
Manny
