trax2004
05-29-2008, 03:49 AM
Hi all! My name is Lasse, i am from Sweden.
I´m on my way buying 2 used SV27 and whant to know what the best upgrades are? From prop to blueprinting the hull. I´ll go LiPo and race in a class up to 15v.
Thanks in advance for your help!:confused2: :confused1:
62 bugzilla
05-29-2008, 08:41 PM
Lots of possibilitys. You can scuff the bottom with a scotch brite pad, as far as prop goes it seems like the x642 for a metal prop and a cf 45 for carbon, cooling changes you can either enlarge the hole in your rudder or ad a pick up tube near your trim tab with some brass on a bracket then also drill out your speedo inlets to a little bigger size but don't go crazy and you can also upgrade the size tubing to the one sold on ose, (all parts are sold here and steve is great ) ose also has a motor cooler that makes a big difference than stock .Water proofing the boat should also be done but if it's a used boat it's probobly done. If you want to change motor and esc thats a whole other story. Do alot of searches in this section and you'll have all the info you could want.
