View Full Version : ESC Timing hobbywing V2 180 amp
arrowskartax9
09-01-2012, 11:24 AM
Hi everyone, What timing can i set my Hobbywing V2 180 amp ESC to?
Iam running twin Castle 1717's in my MHZ Mystic M With Hyperion 18.5v lipos 6s and spinning x447 3 blade props.
Thanks,
Chris.
wade7575
09-01-2012, 04:48 PM
Look here http://www.offshoreelectrics.com/proddetail.php?prod=ker-seaking-pcard it tell's you timing under the Programing card for that esc.
jamespl
09-01-2012, 04:54 PM
I think he's asking what the timing should be for that setup not how to do it.
arrowskartax9
09-01-2012, 05:26 PM
Yes you are correct. I have the programing card i would just like to find out what would be the fastest and safest timing settings for my boat.
How do you have 18.5v lipos that are 6s? You running 5s? Or 6s?
arrowskartax9
09-01-2012, 05:43 PM
Yes, sorry am running 5s 18.5v 35c 6500 Mah.lipos.
arrowskartax9
09-04-2012, 07:32 AM
Any one have any timing suggestions for my set up??
Do you have info on the motors? Kv and wind?
nata2run
09-04-2012, 10:41 AM
You should be able to use 11.5, that motor should handle 6s no problem if it's the 158x kv?
You can also spin bigger props. You should be able to get 120 ish km/h any day....
arrowskartax9
09-05-2012, 08:14 AM
Hello yes they are 1717-1Y-1580KV Motors. I have x447 3 blade and X450 3 blade props.
arrowskartax9
10-18-2012, 06:27 AM
Thanks for your help, Cranked upm the timing to 11.5 and its a rocket. When i got the boat from Rob Mckenna Team FFRB, he set up the timing to 2.
Chris.:rockon2:
Being y wind you could even go up to 15. Although timing change doesn't make any huge difference in speed... You may gain 1 or 2 mph but nothing hugely noticeable
