millzee
08-22-2012, 09:11 PM
When you buy 3 or more items I will throw in delivery anywhere in Australia.
Props.
OSE Balanced @ sharpened in as new delivered condition
*X646 $35
*X448 $35
*M645 $35
*X548 $35
*X640 $35
*x450 $35
*M545 $35
*X646/3 $45
Dasboata Balanced and sharpened- new
*x445 - cupped- $50
*M445 - cupped- $50
Props that need a fix up, some love and a few touch ups
*Grimracer 40X52/3 $10
*Raw X445 $10
*Raw X440 $10
The following props where balanced and sharpened but need a bit of a rework.
*X642 $20
*X447 $20
*M447 $20
*X447/3 $25
*X440/3 $25
http://i1219.photobucket.com/albums/dd439/1millzee/saleitems009.jpg
http://i1219.photobucket.com/albums/dd439/1millzee/saleitems008.jpg
Parts and hardware
*Spektrum Marine receiver MR200 $55
*Spektrum Marine receiver MR300 $85
*2x Etti 4700u 35v eo35 capbank $25
----------------------$25
*Used ose trim tabs- not all bolts supplied $5
*New Speedmaster 40 rudder blade, 1 pick up $15
*New Speedmaster 40 rudder mount 5"set back $20
*New Speedmaster 21 Rudder Assembly $45
*New Speedmaster mini Rudder Assembly $45
*New Speedmaster 40 Rudder Assembly Dual water pick up, 2" set back $65
*New OSE XL Aluminium Turn Fins $15
*Used 1 time, Ose Carbon Fiber medium turn fins $15
*New Ose Large Aluminium turn fins $15
*New Ose 4x 1.5"x1.5" trim tab set $ 25
*Used 1 time, Angled trim tabs, small/medium $10
*14 assorted rubber boots $10
*2x New twin underhull water pick ups, $8each
*8x Medium 2mm fuel line clamps, 4pk $2each
*2x Large 3mm fuel line clamps, 4pk $2each
*New Speedmaster 3/16-.187 Large Strut and bushing $30
*New Speedmaster 3/16-.187 Adjustable stinger drive $50
*Removed from HK Princess- .150 Flex, strut, nut, 5mm-.150 coupler $25
*New Hughey 3/16-.187 Hard 24" Flex Shaft, 5mm-.187 octura coupler, drive dog,
nylon and brass nuts, avid 5mm thrust bearing $40
*2x Octura 24" teflon tube to suit 3/16-.187 flex, (put in 9/32 brass) $5
*34"x20" Carbon/Kevlar cloth $25
*25"x20" Carbon/Kevlar cloth $20
*Delta Force 35" Pirate Mono Offshore FE Hull $225 delivered in Oz
*Delta Force 29" Mono Offshore FE Hull $175 Delivered in Oz
http://i1219.photobucket.com/albums/dd439/1millzee/saleitems021.jpg
http://i1219.photobucket.com/albums/dd439/1millzee/delta%20force%2029/df29long.jpg
http://i1219.photobucket.com/albums/dd439/1millzee/DF35%20rebuild/Hull3.jpg
http://i1219.photobucket.com/albums/dd439/1millzee/DF35%20rebuild/Hull2.jpg
Props.
*X646 $35
*X448 $35
*M645 $35
*X548 $35
*X640 $35
*x450 $35
*M545 $35
*X646/3 $45
*x445 - cupped- $50
*M445 - cupped- $50
*Raw X445 $10
*Raw X440 $10
*X642 $20
*X447 $20
*M447 $20
*X447/3 $25
*X440/3 $25
Parts and hardware
