Mattwarner
08-19-2012, 10:19 AM
Ok guys i am a little stumped on this as my setup seems to be running ridiculously hot and i cant work it out.
Set up as follows
32" rivercat/apparition
twin 3126 1600kv outrunners
t120 esc's
running on 6s1p
originally i was running 45mm props and noticed temps were high (couldnt touch the cans and escs were warm but not hot)
I then propped down to 40mm and still same so played around with timing from the original 15' to 3.75' through to 22' none of which brought temps down, COG is set at 35% and doesnt appear to be plowing but see vid below
http://www.youtube.com/watch?v=M5YBmaOubwk&feature=youtu.be
this vid was the whole run and after bringing back in the cans were soo hot a drop of water would boil on them! wires and escs were very warm as well, i did notice that there was not much flow from the water outlet but as the motors are not watercooled then surely this would only heat the escs? i can blow through the system and appears fine.
Other things worth noting is that drivelines are reasonably free and turn easily by hand, not as free as with the original 4mm drives but certainly not mega stiff, also the stuffing tubes are cold after i come in so doesnt appear to be a lot of restriction here, with the 40mm props amp draw should be fairly low but doesnt appear to have brought the temps down any more than running 45mm's
Batteries are two 3s Hayin 40c 5000mah wires in series and are only slightly warm.
Any help would be much appreciated!!!
Set up as follows
t120 esc's
running on 6s1p
