View Full Version : WTF is wrong now
Big power
08-18-2012, 08:29 PM
Just replaces esc that aquacraft sent me. Turned on controller plugged in two good lipos as before. NOTHING. Tried to bind no light. What is voltage I'm supposed to get on motor leads out of esc? Is that a good test. Could recieved be bad? Just noticed spider crack in hull. How do I send this piece of crap back?????? I was so excited to run this boat had all the upgrade Parts before boat arrived.
Basstronics
08-18-2012, 08:36 PM
I was getting ready today for my maiden.
I plugged in a single 2S and the servo would work but not the motor. Not sure where the LVC is on these.
Maybe its the motor? I would check there. If you have another motor plug it into that ESC to check it out.
Does it even beep when you hook it up? If not then I would say its almost surely the motor.
I put mine in today and wasnt impressed at all. 34.2 MPH out of the box, was hoping for 40ish at least.
Jason4636
08-18-2012, 09:35 PM
I think you need to plug in 2 2s batteries where the esc see's 4s to turn on the motor. If not your lvc won't let the esc work the motor
