View Full Version : SV27 Strut and Rudder on SH?
boater76
05-02-2007, 06:29 AM
I was thinking of using the sv27 strut and rudder on my 40" SH knock off. I am going to use 700sc and Jeti 600 and 14 cells. Anyone think this would be a good application or would I need something different. Thanks.
Ken
ReddyWatts
05-02-2007, 07:26 AM
It should work ok. Probably run in the 20's.
boater76
05-03-2007, 06:08 PM
When a rudder is offset instead of inline does the boat turn differently? I have never dealt with offset rudders.
Ken
saleens7
05-03-2007, 06:21 PM
well, if its offset to the right, it turns right just a tad better, but you also get more speed because the prop wash isnt blocked and it also somewhat counters the effect of prop walk...
boater76
05-03-2007, 06:22 PM
Ohhh I get it. I should have thought about that.
Ken
05-04-2007, 09:37 AM
That's a really large boat for that rudder. Make sure when you mount it you can get atleast 1" of rudder below the prop centerline.
boater76
05-05-2007, 12:23 PM
What's the minimum you think I should go with?
Ken
05-05-2007, 01:21 PM
It really depends on the size of the transom and where it would be mounted.
SJFE
05-05-2007, 06:10 PM
The transom on that boats very tall. You will have to mount that rudder low in order for it to get a good bite.
