View Full Version : Hifei esc's .....pros and cons !
grsboats
08-12-2012, 05:53 PM
Hi guys I'm looking to get a decent esc for a 8S set up with a 1600kv or less motor and would like to hear from you what do you think of the Swordfish 240Hv and the Turnigy aquastar 240 basically similar products.I've been reading reviews and discussions about these products and I coudn't make any conclusion where are the pros and cons of these esc's......your comments are welcome! Thanks Gill
08-12-2012, 10:32 PM
I don't know much about the SF240s, but I do know that the motor you are choosing is almost guaranteed to burn them up. A 1600 Kv is way too high on 8S, even for SAW racing. Go with "or less", a lot less. Depending on the use, boat size and motor size, a Kv around 1100 will work better and be more ESC-friendly in a freely running rigger.
Make-a-Wake
08-12-2012, 11:29 PM
I love my SF240a ESC and also have an Aquastar 240 that is the same ESC, no issues with either.....................I use them solely for over 6s.
jcald2000
08-13-2012, 06:18 AM
I have had the 240 for 3 years and run 180 amps continuous and peaks as high as 372 amps with no problems.
I only run NUE Y wind motors, NO deltas.
bill34207
08-13-2012, 06:40 AM
I ran a Lep 5692 1000 kv (D wind) on 8s in my big mono for a while. The esc handled it fine but couldn't get the timing low enough to keep the motor cool. Still using the same swordy 240 with the Castle 2028 that took the Leopards place. 9 and occasionally 10s 2p with a X457/3. No problems. My swordy is around 3 years old as well.
As for the Lep, it runs better (cooler) on 6s with a Turnigy 180 set at 3.5 degrees spinning a 457/3 in a 54" hull.
grsboats
08-13-2012, 05:54 PM
Thanks Gill
urbs00007
08-30-2012, 12:25 PM
I only run NUE Y wind motors, NO deltas. I'm running a neu 2230 on 12s 18 lb. rigger. presently running fightercat 400 amp 16 s esc seems they're future is not looking good, do you think the 240 would be a good unit for me ?
egneg
08-30-2012, 01:00 PM
I would get the 300 amp HV with added cap bank.
drwayne
08-30-2012, 09:25 PM
SF240HV pre 09-2011 are brilliant.
After that date, the caps are Kr not Japanese.. and extra caps are mandatory to avoid smoke release.
Jp Tsunami washed everyone's preferred cap factory&stockpile out to sea... 8(
There appears to be clones the FC esc from Shanghai ... tsk tsk.
lenny
08-30-2012, 10:11 PM
:tiphat:Thanks for the heads up, And pre date info.
So now where do I find a good cheap hv esc to run 8s and 10s in my stealth mono 48"long with a 5692 730kv for sport running,:noidea:
Whit out seeing smoke release.
drwayne
08-30-2012, 10:24 PM
SF are still great despite that one component downgrade
Ive assembled a pair the TFL Genesis56" ( FC Daytona56) for a LHS with the newer SF240HV & same leo on 12S !.. with a cap bank there's no probs.
Anyhoo.. on a large motor like that, any esc appreciates extra caps , so it's not like it's a penalty..!
as parallel caps, a net return of 3000-4000uf is good ( 63V470uf x8 )
apologies for a quick hijack the thread.
W :bowdown:.
lenny
08-30-2012, 10:46 PM
Thanks,
I thought the Swordfish was having some problems, Like castle did some time back.
And I think it is all good info for this post.:beerchug:
lenny
08-30-2012, 10:56 PM
Gill,:tiphat:
So what kind of boat do you have and what setup ?
grsboats
08-31-2012, 04:34 PM
Lenny it's a cf.rigger designed for saw ...finishing new molds now and will receive a Leo 5682 1360kv on 8S plus a Swordfish 300 a Pro .as soon I have the molds will post in the building section. Thanks Gill
