domwilson
08-11-2012, 06:37 PM
Hello All,
I've been noticing a number of threads asking about flex lubrication. Here is an old post of what some of the more experienced guys are using...
http://forums.offshoreelectrics.com/showthread.php?9324-Flex-Shaft-Lubricants&highlight=lube
I use this stuff myself. I get it from a bicycle repair shop. http://www.triflowlubricants.com/Tri-Flow_Synthetic_Grease.html
It stays put. It's waterproof and I don't get water up the shaft. But others have used different lubes in the list with the same results.
Marine Wheel Bearing Grease (blue)
Grim Racer Speed Grease
Hob-E-Lube White Grease with Teflon
Hob-E-Lube Moly Grease
Tamiya Cera-Grease HG
Mobil 1 Synthetic Grease
Tri-Flow Synthetic Grease with Teflon
Lubriplate “Lube A”
Quantum Hot Sauce Reel Grease
Quantum Hot Sauce Reel Lube
STP (may thin this down)
Lubriplate “Lube A”
