View Full Version : JAE power
joewscott
08-10-2012, 09:21 PM
Hi gang my 2nd post!
Looking for opinions-input on a powerplant for my new JAE.
I'm planning on running 4s and possibly 6s.
thinking the leopard 4082 2200kv or the 4074 2200kv.
and the swordfish 200+ Esc.
What are your thoughts?
Joe
Serpents811
08-10-2012, 10:10 PM
To run a 40mm motor you would have to modify the motor mount if you were to use a Zippkits mount , normally a 4s setup on this tub will consist of either ul1 setup (motor and esc) or you fit a 3674 size motor all you need to do is shave the bulk head behind the motor for better fit , for a 6s setup which more likely is more for SAW racing 4074 1800kv is more than enough ,,,, going back to the spec setup (ul1) this rigger is very nice and reliable
joewscott
08-10-2012, 10:54 PM
Thanks for the reply. So a 3674 would be suitable in this hull? I think you can get up to 2650kv. A little concerned about prop size with that motor? ?
Serpents811
08-10-2012, 10:59 PM
I had a 3674 2200kv with abc h7 prop , how ever I flipped the script and also use a 3674 3270kv with m440 very fast with amp average max 150amps however That setup puts a beaten on your lipo if you don't have good packs
