View Full Version : Thunder tiger outlaw jr. obl rebuild
joshsubmec
08-10-2012, 05:39 PM
I dont have much of a detailed boat build but here it is..my thunder tiger was just to slow being stock so i went ahead and ordered parts for an upgrade...bad idea.:frusty: The new setup im using is a 3650 watercooled
inrunner with a 50 amp esc with octura x440 prop. 2 2s 2200mah batteries(i want to get 5000mah instead but had them layin around). I wan it in the little 12 foot wide canal i got by my house and got speeds around
35-40 mph instead of the 25mph it used to do. Now for the old setup...It had a 1900 kv 29/by19?outrunner brushless motor :tt2: with a 40 amp esc. I used a 3s 2200 mah battery with stock prop. Here are the pics of my
new setup in my boat..82304823058230382306
gyrotron
08-14-2012, 07:25 PM
Can you post some videos? I am thinking about modifying mine too.
joshsubmec
08-16-2012, 09:02 PM
I will try and get some up this weekend if i remember too..im in school now so gotta wait till weekends.:ThumbsDown01:
Wtaylor3
08-17-2012, 09:26 AM
I look forward to seeing videos?...what do u guys think of the outlaw jr with This motor http://www.offshoreelectrics.com/proddetail.php?prod=leo-3674&cat=148 in 3270kv I'm pretty set on the motor as it was recommended to me by the members here I'm just not sure on the kv rating...I want to run 50mph+...I was thinking a seaking ESC in 180-200a and running dual 3s or even 4s packs.
Brushless55
08-18-2012, 01:09 PM
way too much kv, go for more of a 2200, and run 4s on it
M445 prop and have fun!
Acer225
08-23-2012, 10:59 PM
What motor and ESC would y'all recommend for a boat like this
gyrotron
08-27-2012, 01:40 PM
This is the setup recommended by Steven at OSE:
"replace the mount with a ose-80230, This will take modifying the boat and mount.
the motor with a leopard 3650 2290kv,
the esc with a seaking 120
the battery with a 3s 35c 5000mah pack. Use 5.5 bullets on the battery ends. and at least 4.mm bullets on the motor to esc. 5.5 would also be better there."
I hope it helps.
