View Full Version : New MC not working HELP
Big power
08-09-2012, 10:04 PM
Just unboxed new MC. Brand new tested and charged lipos (ran in my slash today). Turn on controller, I plug in both charged tested batts (Grim 5000mah 40c 2s) no beep. I do the T trim trick nothing. I try the N R switch on trim nothing. I try pressing the little button on the receiver to bind the controller, no little LED light. I think the ESC is blown from the factory.
sanyijr
08-14-2012, 03:49 PM
Volt test the power lead as close to the ESC as possible. If you have power there, I would assume esc is bad.... You have a series connector i assume? Could be bad contact there. That is why I say Volt test at esc on the power in side.
Grimracer
08-14-2012, 04:09 PM
2S is not enought voltage to operate the system.
Grim
sanyijr
08-14-2012, 04:55 PM
Grimm,
"LIPOS" I assume here we are working with 2 2S packs.... But you might be right. BigPower?
Big power
08-16-2012, 10:37 PM
http://www.amazon.com/dp/B005EFY7HS/ref=pe_175190_21431760_M2T1_ST1_3p_dp_2
These are the lipos I used?
sanyijr
08-17-2012, 11:32 AM
BP,
So you have two and you hook both up the the stock esc? That make it a 4S setup. If you only have one plugged in, it's 2S and as Grimm stated, low voltage and no good.
Do you have a voltometer? (Volt meter?)
I mean if all is stock, 2 packs 2S each are plugged in, and they are charged..... Looks like a bad esc as assumed...
Wouldn't say "blown". That implied overloading it and the this popping due to use. Most likely a short or faulty solder connection....
Big power
08-17-2012, 01:48 PM
Correct 4s. Aquacraft is sending Esc free of charge.
