View Full Version : seaking 180 6s?
iridebikes247
08-08-2012, 10:39 PM
Hey just curious who runs the seaking 180 on 6s and how many runs you've given it. I am running 1600kv twin leopard/twin seaking combo, temps stay really low. I consider myself a sport boater and have been running on 5s1p per side and I feel like this is a solid setup. Will jumping up to 6s put a lot more strain on my esc? Thanks guys.
oscarel
08-09-2012, 10:14 AM
I do and have been for a couple years now. Most without bec.
Rocstar
08-09-2012, 10:35 AM
I am running a single 1600kv on my Daytona with a sk180 on 6s. Temps on the esc are around 112F
grsboats
08-09-2012, 04:34 PM
I'm running a Jae Fe with 4082 2000kv on 6S and with a little mod on this esc you can run cool..40C.Gill
What type of mods? Im planning to build i saw-cat twin 4082 2200kv on 6s, i have seen others on the same setup with the 180a ESC.
Rumdog
08-10-2012, 05:01 PM
you wont have issues if you dont over prop.
pyroM!KE
08-10-2012, 05:38 PM
I run a leopard 1550kv sk180 on 6s turning a x447-3 detounged and cupped..Temps are 115-120..I wouldnt push it any further than that..Also run 40c packs and disable the bec...
b20btec
08-10-2012, 07:40 PM
I have this esc on 3 boats, two of them are 6s using the sk bec, suppo 3730 outrunners in m445 props. Never seen esc temps past 120, I live in scorching Texas.
Make-a-Wake
08-10-2012, 07:43 PM
I run T180's on 6s with the bec in operation.
The only issue you may encounter is the pre-mature LVC, set it at 2.8v or turn it off and time your runs.................start with a 3 minute run then check capacity when you charge back up. On second thought, if you run a big prop in high heat, they have been known to thermal as well, keep is mild in August.
grsboats
08-13-2012, 07:11 PM
My boat is a rigger made for saw and this is the simple mod .Gill
Make-a-Wake
08-13-2012, 07:43 PM
I modded one too, had some aluminum "L" stock handy so I used it. The larger shape of the aluminum pieces acts as a heatsink as well. Yours looks alot "prettier" than mine.
Skullcracken
08-13-2012, 08:11 PM
You should be fine on 6s. A lot of guys run 1600kv 6s setups in single drive cats or mono's. With a twin setup, each motor/esc side will run more efficiently than a single drive. You should have no worries. That boat will rip on 6s each side. What the heck do you have that in?
traeside
08-18-2012, 09:38 AM
i am looking to get one of these Seaking 180's but not having one in hand i am not understanding the cooling mod. well it be obvious when i get it in hand?
traeside
08-18-2012, 11:35 AM
i see it now that i found the other cooling thread. :thumbup:
