iridebikes247
08-05-2012, 02:11 PM
819478194881949
#1- Turnigy t600 outrunner mint condition, SOLD
#2- Turnigy t600 outrunner used condition, PRICE DROP, $35
#3- Turnigy t600 outrunner used condition, $25. Story on this motor, my dremel slipped when working on the boat and cut into one of the motor wires and cut a few of the wires. I tested the motor outside of the boat and it ran fine but I have NOT tested it under load in a boat. Motor outer casing is also scratched up badly but no way affects motor performance/structure. Motor responds perfectly to throttle inputs, this would be a great test motor for new projects.
Note: The second and third t600 motors in this listing lack the C-clip usually attached under the coupler. This is a non issue if you purchase a thrust bearing, I have used several of these motors and a thrust bearing is an absolute MUST as the tiny clip takes quite a bit of strain without one. Thrust bearing will be supplied with purchase ($10 value in OSE store). Also listed prices do not include shipping.
2 couplers 6mm to .187-$6 each
Speed controls listed
2 Seaking 120a- SOLD
