View Full Version : My P1 35" sub floor came completely unglued from the hull.
rjsmachz
07-28-2012, 10:56 PM
My boat is 11months old....no accidents and my sub floor came completely unglued. Any suggestions for fixing? glue types?
antslake
07-29-2012, 09:56 AM
Epoxy resin. I layed an additional layer of fiberglass in my hull. If you plan on doing speeds more than 25mph you should do the same. The gel coat will crack.
EricSchlaifer
07-29-2012, 04:55 PM
On some of the boats the wood also could use another coat of a poly resin since its quite thin. This will help keep the wood sealed.
lenny
07-29-2012, 11:39 PM
I pulled my wood out for the cells,
To get a lower cg in the hull.
My cells are on the floor of the hull now and it help a lot for smooth running.
