View Full Version : 4s battery on stock motor
minizoom
07-27-2012, 01:22 AM
My stock esc died just after 5 packs on 3s. I replaced the stock esc with a 30a esc that can handle 4s. Would the stock motor be able to handle the 4s?
roadrashracing
07-27-2012, 10:30 AM
might be to many rpms for the motor
minizoom
07-30-2012, 03:58 PM
Ran a 4s 850 mah batt today. It so fast compared to the 3s. It was almost boring to run 3s. Only ran it for 3 mins. Motor temp after the run was 95f and esc was around 90f. I only ran the 4s once and 3s another 7 runs back to back to torture test the esc and motor.
kyrzrone
07-30-2012, 07:57 PM
What ESC did you go with?
minizoom
07-30-2012, 08:07 PM
I'm using a modified 30a Hobbywing aircraft esc. Basically I took the cooling pipe off the original esc and jb weld it onto the hobbywing and re-shrink it. I also jb weld the cooling pipe that is ziptied on the motormount. Almost forgot to mention that I silicone sealed the esc.
http://i437.photobucket.com/albums/qq94/alvinbustamante/20120730_170952.jpg
kyrzrone
08-05-2012, 09:15 PM
Minizoom how has your 30a Hobby Wing esc been holding up on 4s? Any programing or over heating issues?
minizoom
08-05-2012, 10:04 PM
No issues so far. The highest temp I got from the esc is 97f. The only problem I've had was all three hobbyking 4s batt puffed. I''m not sure if that due to age though. My run time on 4s 850mah is only 2 mins then slows down.
