Tunnel Hull (TS3) Water Cooling Inlet...How would you do it?
  • capnswanny
    • Feb 2012
    • 817
    How would you pickup water?
    I'm getting really close to run (next 2-3 days) with my TS3 build. I have a new REK leg (thanks Jr) with no pickup holes drilled aft of the prop. Last leg I had (stripped threads...probably my fault) had the pickup behind the prop on the leg, but I was thinking I might want to shorten the cavitation plate to accomodate a larger diameter prop than 42mm? (OK, I guess thats a question too
    What do you think? Pickup behind the prop on the leg and stick w/42mm (I have a GR-42/55)? or....Transom pickup w/tube? or....Fancy thru hull pickup block at the stern (as seen on OSE)?
    Running 1800Kv (aka ~1500Kv)/AQ60A ESC now, but might want to move up to 2030Kv AQ motor.
    Thanks all!
    Corey
    This is NOT a toy?!?
  • marko500
    • Aug 2008
    • 861
    I have a K&B 3.5 that someone cut most of the cavitation plate off of. Kicked around the idea of how to mount a pickup too. Ended up making a new plate out of aluminun and putting the pickup where it was originally, behind the prop. Cut what was left of the old plate down leaving just enough to put 4 bolts through, 2 on each side , to hold on the new plate. Works great. My other idea was some kind of prop wash pickup.
    • capnswanny
      • Feb 2012
      • 817
      Did you ever want to go up in diameter on you prop?
      With this leg I can drill a hole in the plate to accomodate a pickup, I was just concerned with the lack of prop size restriction.
      I love the prop wash pickups, wonder how it has been done on the outboards?
      Thanks for the quick reply!
      Corey
      • marko500
        • Aug 2008
        • 861
        By doing what we did it raised the cavitation plate a little over a 1/16 of an inch allowing a larger diameter prop to clear the plate.
        • marko500
          • Aug 2008
          • 861
          If you're not racing, with your setup the 42 prop should be fine. He's running a Dumas Hot Shot ABS with a Turnigy Typhoon 500 outrunner and his prop is a either a detounged 440 or 442. And his boat flys and everything stays nice and cool.
          • capnswanny
            • Feb 2012
            • 817
            Thanks,
            I'll put it in the stock location in the plate and run 42's. Not like you can't hack it off later!
            Appreciate your advice!
            Corey
