View Full Version : what prop to use
itspfo
07-23-2012, 12:13 AM
ive got a 32 in cat running a leopard 4074 with the t-180 esc need a prop
stadiumyamaha
07-23-2012, 12:56 AM
That's the kv of the motor and what's your cell count?
stadiumyamaha
What's the kv that is.
itspfo
07-23-2012, 05:53 AM
2000 kv
Diegoboy
07-23-2012, 09:06 AM
thread moved
07-23-2012, 09:54 AM
If you are running 4S then props between an m445 and m645 would probably be appropriate. In the summer you may need to be careful as high water temps won't cool as well.
stadiumyamaha
07-23-2012, 09:58 AM
I've had great luck with both props fluid mentioned. May also try a x632 or even some of the cheap carbon props until you find a size that works.
