View Full Version : fightercat 300a ESC
worriedsick4u
07-21-2012, 04:03 PM
I have my esc programmed. When I connect the batteries I get a series of 3 beeps continuosly. ESC does not respond. Any ideas? And what is the 4 wire lead for? External BEC? Thanks guys
sampit
07-21-2012, 04:23 PM
After the beeps hold full throttle for around 7/10 seconds
When the motor kicks in let go then you should be good to go
You need to do this each time you connect the lipos
I think the four wires are for conecting twin escs up
worriedsick4u
07-21-2012, 04:28 PM
Thank you
sampit
07-21-2012, 07:02 PM
Did it work?
worriedsick4u
07-21-2012, 07:03 PM
Like a champ. Thank you
sampit
07-21-2012, 07:18 PM
I got two new ones I haven't used yet
I read that they are a bit hit and miss
Work really well or fry on the first run
On 6s you need to keep a close eye on temps
What setup you running it with?
worriedsick4u
07-21-2012, 08:53 PM
This is it....
http://forums.offshoreelectrics.com/showthread.php?32900-Phil-Thomas-Supersport-45
carlcisneros
07-21-2012, 10:17 PM
81235
the plug with the 4 wires are for firmware updates only.
start at 5deg for timing and watch the temps closely.
see the attached latest FC instructions.
worriedsick4u
07-21-2012, 10:29 PM
Thanks Carl
