View Full Version : voltage cutoff
hydroman2112
07-18-2012, 11:18 PM
wanted to know if anyone could tell me voltage cutoff for 8s
stadiumyamaha
07-19-2012, 12:01 AM
Whatever low voltage your comfortable with per cell x 8
07-19-2012, 07:13 AM
I usually set my cutoffs at 3.2 volts per cell = 25.6 volts for an 8S pack. But I almost never run to the LVC.
detox
07-19-2012, 12:07 PM
Edit: My Grimracer packs have printed on battery. Never discharge below 3.4V volts per cell.
hydroman2112
07-19-2012, 01:32 PM
the ones i have are zippyflight 14.8 45c
07-19-2012, 01:40 PM
My Grimracer packs have printed on battery. Never discharge below 3.7 volts per cell.That is totally silly, the nominal voltage of a LiPo i s 3.7 volts. Most RTR ESCs have cutoffs around 3.0 volts. Either that's a missprint or it means resting voltage, not LVC.
detox
07-19-2012, 01:52 PM
Sorry I misread package. It states "Never discharge below 3.4V per cell"
I ran one mill lap and 6 race laps using this single 4200 mah pack in my LSH Whiplash. Pack came back puffy and very warm. My Hyperion charger showed 20% remaining and 3.7 voltage percell while recharging. Switched to larger 5000mah pack for less heat and less voltage drop for faster speeds near end of 6 LAP heat race.
richard
07-20-2012, 08:49 PM
i want to see if some can help me ? i have set of 4s battery i run in 2p and of them dischargeing more the one.
jcald2000
07-21-2012, 06:52 AM
Carge them both in 2P at same time so the work togeather, may take 2 or 3 cycles to see if they will match up.
