View Full Version : Throttle Sensitivity, Seaking 180/Tactic radio
Checkmateguy01
07-17-2012, 07:31 AM
I'm trying to figure out how to set the throttle to be more linear on my Seaking 180 ESC. Right now it's full throttle or nothing. I have to pull the trigger about half way before it takes off, then it's right to full throttle. I've done the throttle calibration a couple of times but it didn't change it. Plus i've messed with the throttle trim on the transmitter too. What am i missing?
Heaving Earth
07-17-2012, 07:52 AM
Your throttle should be set to reverse and the trim all the way up when you calibrate.yes?
Checkmateguy01
07-17-2012, 04:23 PM
I'll have to try that, but i did just look and the throttle was set to reverse. I don't remember if i had the the trim all the way up or not. I just wondered if that was the way the Seaking 180 was, no part throttle running.
SirBudman32
07-17-2012, 05:17 PM
I have the Tower Hobby version of the Tactic radio on 2 t-180 and have full throttle curve with it. Set to reverse and trim all the way up.
Checkmateguy01
07-19-2012, 05:27 PM
Cool, thanks, i'm gonna mess with it tonight cuz i'll be running the boat over the weekend. Do you back off the throttle trim after you have calibrated the throttle/ESC?
Heaving Earth
07-19-2012, 05:45 PM
No. Leave it cranked
Checkmateguy01
07-19-2012, 07:15 PM
Thanks ya'll, worked like a charm!! Boat might handle a little better while turning now!
Heaving Earth
07-19-2012, 07:22 PM
Glad it worked
brew99
07-20-2012, 11:12 AM
Are you suppose to crank the throttle trim on all radios when cal the T-180 or is it just for this specific Tactic radio? I don't use a tactic, and never heard of turning the trim all the way up before calibrating, but I'm assuming that it just allows for max throttle output from radio
Heaving Earth
07-20-2012, 01:20 PM
No it depends on the radio. My flysky needs throttle set to reverse, but doesn't need the throttle trim moved from 0
brew99
07-20-2012, 02:55 PM
Thanks, I use a flysky also
