View Full Version : Lead Teflon or brass bushing for this strut
BHChieftain
07-16-2012, 02:11 PM
I am running a new 1/4 inch stuffing tube and I can either run it all the way through the strut and use a brass bushing for the 3/16 prop shaft, or I can run it just past the back lip of the strut and use lead teflon bearings. Any strong recommendations either way?
Chief
properchopper
07-16-2012, 03:55 PM
My take is your choice #2. Makes strut adjustment easier & I've personally been favoring/converting to lead-teflon in my boats. Even recently converted a Spd stinger to L/T.
BHChieftain
07-16-2012, 05:46 PM
Thanks properchopper
Heaving Earth
07-16-2012, 06:29 PM
i prefer the brass bushing as theyre much easier to change. not sure if propper has figured an easy way to change lead teflon bushings? please share
properchopper
07-16-2012, 06:55 PM
Here's how I installed L/T in a shortened Spd stinger. Same would go for a conventional strut :
Knocked out the brass liner with a drift ( not necessary with some struts like Speedmaster which are bored for .250 shafts already, only their stingers have the internal bushing))
80940
pressed in the front (of boat) bushing
80941
used drift to insert to proper depth
80942
EDIT : Do same for rear (of boat/prop end) using vice press - no picture
chucked up a propshaft, used light oil to lap bushings
80943
To remove for replacement, just knock 'em out with drift. :thumbup1:
BHChieftain
07-17-2012, 12:40 AM
Good stuff
properchopper
07-17-2012, 12:49 AM
Good stuff
Just looked at the post; had the pictures messed up:doh:; check now.
BHChieftain
07-17-2012, 12:33 PM
Ok, just did a test run using the lead bearings with the stuffing tube just past the lip-- works great.
Chief
siberianhusky
07-17-2012, 01:46 PM
For this I use my drill press as a press, short length of 3/16 rod with a airplane wheel collar to press them in. Old 1/4 drill bit in the chuck backwards to press them out to to depth.
LOL I have the same drill press vice as Tony. Cheap bugger!
