View Full Version : ProBoat water jacket change to 90 deg nipples?
JimClark
07-15-2012, 08:40 PM
Anyone found any 90 degree nipples that will fit the proboat water jackets?
Jim
stadiumyamaha
07-15-2012, 09:32 PM
Of you find some please let me know.
JimClark
07-15-2012, 09:35 PM
might end up just buying a silicone water jacket so the tubes don't exit straight up
07-15-2012, 09:43 PM
might end up just buying a silicone water jacket so the tubes don't exit straight upBe prepared for a boat full of water. Every silicone jacket in our club boats leaked like a sieve after a short time, even with plenty of bathtub caulk around the edges. Better to plug the existing jacket holes and re-drill for the nipples below. That way you can put them in the right places - exit high on top, inlet as low as possible.
http://www.offshoreelectrics.com/proddetail.php?prod=etti-a029
tryinotocrash
I don't know what the thread is on the water jacket but check these out. Scroll down a bit and there are several 10-32 90 degree and swivel fittings. .http://www.mcmaster.com/#standard-barbed-tube-fittings/=if9hjn click on the brass fittings on the left and scroll down.
stadiumyamaha
07-15-2012, 10:17 PM
What size motor are you using? I've got a new Traxxas silicone water jacket you can have. Works well on the spartan 36mm motor.
JimClark
07-15-2012, 10:20 PM
36 mm diameter is what the proboat motors are
stadiumyamaha
07-15-2012, 11:53 PM
If you need it let me know.
JimClark
07-16-2012, 01:11 AM
Pm sent thanks stadiumyamaha
Sent from my MB611 using Tapatalk 2
roadrashracing
07-16-2012, 01:16 AM
could use these and tap the hole if need be:
ray schrauwen
07-16-2012, 09:37 AM
The holes are 4mm thread. Steve sells 90 degree fittings that fit http://www.offshoreelectrics.com/proddetail.php?prod=etti-a030
But, IMO it would be better to have the 5mm threaded Leopard 90* fittings, they will flow much much more water and be that much cooler.
The Chinese fittings are cheap but, they flow allot more than the above 4mm or even the brass 5mm threaded ones Steve sells (HRC type replacements)
I'm going back to the chinese fittings. When it's in the right position, add slow set epoxy or some CA to set them in place and no leaks.
After burning up 2 UL-1's at an event 2 weeks ago, I've been relearning cooling practices.
This 90* days and 90* water is challenging!!
