View Full Version : Tried the 2030Kv
Shovelnoserc
07-15-2012, 07:28 PM
Did not run well with the stock prop, took a while for it to plane, I had a carbon 45mm I think 63ish pitch, and it's the ticket, gets on a plane immediately and I did not notice anymore chine walk than normal, actually I thought it ran much better. It has a nice top end and a lil tuning on the fins so that it does not go diving when I turn, temps where normal. I had a perfect day. A few friends took some video, I'll see if I can get it uploaded to YouTube. I'll post the link if/when it happens.
stadiumyamaha
07-15-2012, 08:28 PM
Cool. I've been planning to put that motor in mine. Just not real happy with the speed of the stock motor.
Big difference in speed?
Shovelnoserc
07-15-2012, 09:57 PM
I ran the prop with both motors, it's definitely faster due to the prop, I believe it's a bit faster with the UL-1 motor, but I have to GPS the runs to have some facts.
ray schrauwen
07-16-2012, 09:55 AM
I wish someone would start casting Graupners Carbon props. I like them so much but, would be so much better in Ber/copper/Ti...
They handle so much different from other props, specially for chine walk. Too bad they wear but, cheap!!
Shovelnoserc
07-22-2012, 06:50 PM
Well, the videos from last week did not get recorded. Lol.
We took some new ones today. I hope they are up in a few days so that I can post the links.
This time I installed the OSE small carbon fiber turn fins. Just got them barely touching the water as the stock pair was making my nose dive in too much at the turns. Tried to raise the trim tabs but, they are so hard they won't come up. They will adjust down but not up.
I am renaming my revolt, the screaming chicken ( I am an MR2 owner and that name is used to identify one of the hood bages.)
Shovelnoserc
07-23-2012, 07:08 PM
Pics of my revolt for now, videos are not up yet. I'm recording my own next weekend.
http://i269.photobucket.com/albums/jj65/SR-1ION/86129489.jpg
http://i269.photobucket.com/albums/jj65/SR-1ION/ddecb028.jpg
http://i269.photobucket.com/albums/jj65/SR-1ION/a80ff30a.jpg
http://i269.photobucket.com/albums/jj65/SR-1ION/68107b7f.jpg
gyrotron
08-05-2012, 01:21 AM
[QUOTE=Shovelnoserc;438295]Pics of my revolt for now, videos are not up yet. I'm recording my own next weekend.QUOTE]
Hello Shovel,
What are those two aluminum buttons popping up the hatch? Are they purely decorative or are you fastening the hatch somehow?
osprey21
08-05-2012, 05:05 AM
Hello Shovel,
Those look like water outlet fittings (note the two loose cooling lines over the transom).
http://i.imgur.com/aiPXS.jpg
gyrotron
08-05-2012, 10:34 AM
Ok, I see now. Thx.
Shovelnoserc
08-06-2012, 02:26 PM
Yup that's what it is, on other news my brass bolt failed to break and I tore my transom up a little bit. I got home and fixed it on the inside. I'll take a picture of the outside crack so you guys can see it. Also my hatch took a beating too.
gyrotron
08-06-2012, 04:27 PM
Sorry to read that. How fast was your boat going?
gyrotron
08-06-2012, 04:34 PM
Shovel,
Did you modify the stock setting of the trim tabs? How do you have them setup?
Shovelnoserc
08-06-2012, 06:59 PM
I don't know actual speed, I was maybe 3 lengths behind a 4082 2200kv mystic (53ish mph) and about one length behind a 3674 2200kv mean machine (haven't gpsd yet). It was a just for fun run, I had them at the corners and they would catch up on the straights. About the 3rd lap I dove (that unbalanced the battery locations) and then on the final lap I hit a buoy. Kept on til the end. When I brought it in it was a mess.
@gyrotron
I've not done much to the tabs as I find it a lil nose heavy and it dives quite often. I've looked to raise them but they don't go any higher. I raised the strut and got the turning find out of the water. No chine walk.
Still using the 2030 and the carbon filled 45/63. I modified a 42 3blade (4mm threaded) and tried it as well. Not as fast but it seemed to have a higher lift and the boat ran much drier and very stable.
Shovelnoserc
08-06-2012, 07:24 PM
The lid, lost a few chunks and stressed cracked all over.
http://i269.photobucket.com/albums/jj65/SR-1ION/65730225.jpg
Repaired with a 3oz cloth and a two part west system epoxy resin mix.
http://i269.photobucket.com/albums/jj65/SR-1ION/845fe751.jpg
The back view.
http://i269.photobucket.com/albums/jj65/SR-1ION/ee098d17.jpg
Top view, the gap used to be wider but, I clamped the transom as it was drying and I was able to close it a lil.
http://i269.photobucket.com/albums/jj65/SR-1ION/79de2124.jpg
gyrotron
08-06-2012, 09:19 PM
Man... not a pretty sight. But for what you are telling it sounded like a lot of fun. I hate round buoys I rather run around noddles. What are you planning on doing now with the boat?
Shovelnoserc
08-06-2012, 09:33 PM
The Boat is pretty much back together. Installing the hardware was tough "needed smaller hands" but got it done. It I'll be ready for Sunday. Don't know about my batteries tho.
gyrotron
08-06-2012, 09:45 PM
Good to read that. I assume you will be doing some test runs before Sunday. Good luck!
Shovelnoserc
08-06-2012, 10:39 PM
Yeah, Thursday or Saturday .
Brushless55
08-09-2012, 10:28 AM
I'll have to try 1 of those props when I get mine
D for Dummy
08-20-2012, 04:11 PM
I thought of putting water outlets out the top of my Motley Crew and Revolt hoods, only I was worried that while upside down, they may leak (no matter how well I seal them up - glue or silicone). Looks good. How does it hold up?
Shovelnoserc
08-20-2012, 10:25 PM
the outlets dont leak at all, the holes are a real tight fit and I used a very small amount of silicone when I reinstalled them this time (after laying that piece of mat). The first time I did not notice any leaks from the outlets. The boat has leaked through the Shaft tube, the boot and water inlet lines.
Jersey Crewmax
10-01-2012, 07:26 AM
So overall do you think it was worth swapping in the 2200?
Shovelnoserc
10-02-2012, 07:02 PM
The 2030 was ok. It was an old motor had been in a lot of boats and it went out during a run. Went back to the 1800kv and now I can't notice the difference I think the 2030 was not at peak performance.
A friend installed a leopard 3674 2200kv and it proved to be too much for the boat super fast but too unstable.
The 1800 on 5s is fun too.
stadiumyamaha
10-02-2012, 08:25 PM
I really like the 2030 motor in my revolt.
Running a 642 prop with a little pos strut. It rips.
