I purchased the 125 barricuda awhile back, and nemisis 14xl, but i cant seem to get it to arm or figure out how to program this thing???
Barricuda125 ESC HELP!!!!!
Tags: None
Programming with the transmitter is a pain. It takes time and a cool head. The arming may be an issue with the throttle adjustments on your transmitter or try the reversing feature on the transmitter.Steven Vaccaro
Where Racing on a Budget is a Reality! -
I use the castle link with mine, sometimes when I change the motor timing I have to reset the throttle adjustment..Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"Comment
HI,
I have a couple of Barracuda 125's and would like to know how to set the low voltage cut off on them.. What do I need to buy as far as a link to program it into them?
Is it easy to do?
Thanx in Advance :)
Tom H .Comment
