View Full Version : TS3 radio box mounting...suggestions?
capnswanny
07-01-2012, 11:25 PM
So I'm finishing up the box for my ts3, I was planning to use 3M double sided tape to hold it down, same tape I use to hold the rear sponsons on my rigger, is this a good idea? I know I'm a bit behind the times for new builds, but I'm looking forward to seeing this hull carving the lake! Thanks! Corey
Diegoboy
07-01-2012, 11:28 PM
Does your box need to be removable? Exactly what 3M tape are you talking about? The foam mounting tape or the grey putty-like tape used to mount car emblems?
http://ak.buy.com/PI/0/500/228342226.jpg
http://ecx.images-amazon.com/images/I/51Fqd1oODbL._SL500_AA300_.jpg
capnswanny
07-01-2012, 11:34 PM
The grey putty like tape....cut it of with a guitar string type stuff. I just like the idea of possible remove...
Diegoboy
07-01-2012, 11:36 PM
If it must be removable, that's what I would use!
capnswanny
07-01-2012, 11:37 PM
Thanks!
capnswanny
07-02-2012, 12:07 AM
Would you advise against removable? I would certainly epoxy it in if there were gains from it.
Thanks again for your advice.
properchopper
07-02-2012, 01:43 PM
Corey , Once upon a time I has two TS-2's where I could transfer the box between them. Might give this concept a thought :
80132 80133 80134
80135
I've found that for many applications tape works well but after it gets wet (as it will in the TS-3) it loses it's gripping power.
capnswanny
07-02-2012, 09:19 PM
I like it! Thanks for the pictures....a thousand words!
Perfect option for me since I over cut a bit aft, wood will fill it on nicely!
