View Full Version : Venom KOS P1 Twin Outrunner Setup
Alfa Spirit
07-01-2012, 12:05 AM
Hi,
I have the opportunity to buy a new hull undrilled with hatch for a very small price and I have a set of FMT outrunner motors 36 x 50mm, 1700kV Setup
Rumdog
07-01-2012, 09:44 AM
So, you did, or didnt buy one yet?
http://forums.offshoreelectrics.com/showthread.php?33028-Bought-a-Ekos-P1-hull
Alfa Spirit
07-03-2012, 05:55 AM
Hi,
I need a picture of the V hull from the back, thank you
Alfa Spirit
07-15-2012, 02:39 PM
The Venom P1 will be discontinued, hull/hatch set is no more avalaible in online shops. Only 2 or 3 pces are in stock at Venom Group shop BUT I' ve found a new Hull/Hatch Set - P1KOS, I really love that Fountain hull.
What do you think about the setup?
http://img856.imageshack.us/img856/7642/p1hull8.jpg
Alfa Spirit
07-19-2012, 06:45 AM
Help! I need your advice, I don' t know the Venom KOS P1 hull
lenny
07-19-2012, 06:59 PM
What do you want to know about the hull ?
Alfa Spirit
07-22-2012, 03:24 AM
Hi,
I want to know if turn fins are necessary, same question for trim tabs. Thanks
tlandauer
07-22-2012, 04:05 AM
I bought a used one from a member here who installed the small turn fins and trim tabs,http://www.offshoreelectrics.com/proddetail.php?prod=ros-spdt-150 http://www.offshoreelectrics.com/proddetail.php?prod=ose-80060 the boat runs well with them, can't tell you how it would run w/o them, but I remember earlier version came without one of the items. Current version that is in stock has a fin/tab combo. My feeling is that for a single drive one is better off with them, but I have no knowledge with twin drive set ups. I can tell you that the in-line rudder doesn't work as well as the off set rudder that Lenny here moded himself. We had exchanged quite a bit of notes few months ago. I was going to copy his but got hopelessly distracted with new projects.
lenny
07-22-2012, 11:35 AM
What are your plans for the boat, Scale fun running and sport or high speed and saw runs ?
Hear a link on my modding so far and info with videos to,
Read through the info and it may help you.
http://forums.offshoreelectrics.com/showthread.php?32137-P1-kos-35-quot-offset-rudder.
Also member Jesse J did a over hall on one,
http://forums.offshoreelectrics.com/showthread.php?19418-P1-overhaul
And also did some twin setup on some scale mono a long time ago.
Check with him on his testing on them.
Alfa Spirit
07-22-2012, 11:51 AM
Hello,
My plan is high speed, what do you think about the setup, is one 6S battery enough? I sent a PM to Jesse but no reply. The hull is on the way, so can you tell me if there is holes in the hull? I hate turn fins, if the P1 can run fine without those parts, that' s good, Thanks
lenny
07-22-2012, 12:54 PM
If just going straight at high speed with twins is what you want,
You may not need the turn fins.
But the boat torque roll easy if not setup right,
I would think two 5s packs in parallel would be safe for the setup you are thinking.
Not sure about if it will come predrilled, With holes.
Where did you buy the hull and hatch from,? Have a link.
Alfa Spirit
07-22-2012, 09:30 PM
P1 hull + hatch are no longer available, I looked to webshops and it' s always out of stock. May be Venom will stop the P1 KOS. So I bought the P1 at Venom shop but it' s very expensive...
Alfa Spirit
08-05-2012, 10:11 AM
I use stingers from HOR, lenght is adjustable 85mm to 105mm, very well build and not expensive 30US$ each
Alfa Spirit
08-15-2012, 11:09 AM
I use 5S 5000mAh batteries with an other boat, do you think I can use those batteries paralel wired in the P1 KOS? Not too heavy?
With 5S motors take 31500 RPM and 37000 RPM with 6S
Alfa Spirit
08-18-2012, 10:08 AM
I will run 5S setup, I think that 32000 RPM is enough for this mono P1 hull. Small metal propellers are available at MHZ for 3/16'' shafts, normal and reverse rotation
http://img824.imageshack.us/img824/2229/ztuning733.jpg
Alfa Spirit
08-18-2012, 10:23 AM
PS : people ask me where this motors mount come from, I assembled two single motor mount, here is the link :
http://cgi.ebay.fr/Xpower-B36-540-550-Adjustable-Alu-Brushless-Motor-Mount-RC-Boat-Water-Cooling-/180876491816?pt=UK_ToysGames_RadioControlled_JN&hash=item2a1d143c28
lenny
08-18-2012, 06:55 PM
They look like nice mounts and stingers,:tiphat:
How much are they US dollars shipped each ?
Alfa Spirit
08-19-2012, 05:01 AM
Stingers come from HOR,
http://www.horracing.com/product_info.php?products_id=430
Alfa Spirit
09-04-2012, 12:23 PM
I had oportunity to buy a pair of Scorpion HK-3026 1400kV new in the box , this model is discontinued, that's why I bought them for a very very good price.
What do you think with a 6S 6000mAh battery? Around 32000 RPM unload.
Alfa Spirit
09-05-2012, 04:58 AM
An other picture This P1 hull is nice, finish is very nice too
Alfa Spirit
09-05-2012, 11:42 AM
Instead of one battery I will use two 3300/4000mAh batteries, something like this Zippy http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=21358 Total capacity = 7400mAh, total constant discharge = 185A
http://img600.imageshack.us/img600/7099/p1hull23.jpg
JrValente
09-05-2012, 01:41 PM
It's useless until you install some hardware on that boat.
Alfa Spirit
09-10-2012, 01:42 PM
What do you think? I need your advice
Alfa Spirit
09-20-2012, 03:05 AM
Long bracket and T bracket part fit well for the inline mount :laugh: Rudder blade is shorter.
http://img585.imageshack.us/img585/329/p1hull26.jpg
Rumdog
09-20-2012, 09:08 AM
Build something!
Alfa Spirit
10-06-2012, 10:11 PM
I' ll put the Scorpion in the Rapid, the P1 KOS will be powered with twin FMT 3650 1700kV with 2x5S
Alfa Spirit
12-18-2012, 01:21 PM
The rudder is a TFL model with 3 carbon plates for a longer bracket
lenny
12-19-2012, 02:13 PM
Hears a old twin that runs for some info. :popcorn2:
http://www.youtube.com/watch?feature=player_embedded&v=1N_lZXkf2rY
http://www.youtube.com/watch?feature=player_embedded&v=7AC4F-7lymQ
Alfa Spirit
12-19-2012, 05:09 PM
I made a motor mount for the twin FMT outrunners, without that ugly orange color
Alfa Spirit
12-19-2012, 06:45 PM
Those 70mm stingers are very cool. Flex cables are 1/8" and shafts are 4mm, they are glued with Loctite 648. I use 4mm to 3/16" adapters for propellers.
I like the result
http://img525.imageshack.us/img525/2536/p1l62.jpg
Alfa Spirit
12-20-2012, 02:20 AM
Here is the drive hardware, cheap but those parts look nice and strong :thumbup1:
Alfa Spirit
12-25-2012, 10:33 AM
Rudder and stingers alignment
