View Full Version : Wanted... Little Screamers 650KV Outrunner or similar
BulletMaster
06-19-2012, 04:48 AM
Hi guys,
Hard to come by I know.. but anyone have a LittleScreamers 650KV outrunner for sale? Or can anyone suggest similar power system to handle 12S in a mono?
Must be able to ship for a reasonable price to Australia..
Thanks for looking...
FOUND A SOLUTION THANKS GUYS!
drwayne
06-25-2012, 08:51 AM
Hi TJ
MHZ have a line of watercooled scorpion outrunners....
Gutsy too !
Ive a pair 5035-760s in a 142cm cat.... Outrageously overpowered on 12S1P shared.
http://shop.mhz-powerboats.com/E---Motoren/Scorpion-Motoren/
cheers
W
BulletMaster
06-25-2012, 09:10 AM
thanks W... having a look..
hmmm thanks for the suggestion... but a little exe for me.. Would probably go the neu route if I was in that spending ballpark..
Trying to do this one on the cheap.. might look at modifying a HK motor to do something (like my 50cc electric MXSR)..
drwayne
06-25-2012, 09:13 AM
what rpm/watts you aiming ?
cheers
W
BulletMaster
06-25-2012, 09:56 AM
looking to spin a 67mm prop around 25k... running 12S1P 5800 packs..
Thinking around 3KW would be good for an X sized mono
drwayne
06-25-2012, 10:09 AM
5800's ? hehe
I ran 2x5692/730 on 12S1P shared for 2+ mins in big cat.. returned packs warm, V at 3.3ish
Amp draw is child's play in x mono... !
cannot beat the cheap leos for value,
http://www.offshoreelectrics.com/proddetail.php?prod=leo-5692&cat=148
540Kv to 12S equates @25k loaded.
Ive a pair new 5692/730 here for sale, but they're a set...
W
W
drwayne
06-25-2012, 10:54 AM
Oops. Meant to say a pair at 1090 avail. 73Os already spoken for :smile:
Run 6s2p
W
BulletMaster
06-25-2012, 11:04 AM
it's gunna be an EC class boat Wayne. The leopards look good... might be the option I take. Are they particular about which ESC they play with?
drwayne
06-25-2012, 06:40 PM
12S1p id go 5692/ 540Kv.
I run ( of course ) the SF240HV with extra caps.
The latest have loggers :smile: as do the 15S300A
caps are 63V470uf low esr, 3series pair in //
79679
79680
BulletMaster
06-25-2012, 09:12 PM
Wayne... where did you get the datalogging version of the SW240HV from? I managed to get a 200A LV unit with datalogging, but they are hard to come by..
BulletMaster
06-25-2012, 09:22 PM
http://www.youtube.com/watch?v=klCDPtIpbkk&feature=related
H (http://www.youtube.com/watch?v=klCDPtIpbkk&feature=related)K Osprey with 12S setup and the motor you suggested above.. would be interesting to see some circuit speeds..
drwayne
06-25-2012, 11:27 PM
Looks like that fella had radio issues, going everywhere at once didnt do it justice !
W
scottw
06-26-2012, 03:19 AM
BulletMaster
you can get the Swordfish HV 240's with datalogging from Joe at RCboatbitz - he will post worldwide
http://www.rcboatbitz.com.au/
scott
drwayne
06-26-2012, 06:24 AM
BM, he also sells corrosion X in pump spray bottles.. !
Gr8 for water proofing electronics.
W
BulletMaster
06-27-2012, 03:43 AM
ta for the great info guys...
RandyatBBY
06-27-2012, 06:05 PM
I have one I am not using, If you still want the little Screamer $150. Plus cost of shipping.
