View Full Version : ANOTHER victim of MAXAMPS over rated lipos
Serpents811
06-18-2012, 05:10 PM
Here is my story , purchase a 6500mah 4s maxamps rated at TRUE 150c "burst" 75c continues , batt was starting to over heat and puff , maxamps checked the history of the pack and the pack was over a year old sitting on the shelf of the hobby shop ,I was told by Dustin at maxamps that the polymers on the lithium plates will cristalise over time and won't produce the power required , new pack was received and put to the test , now this pack is being use on jae 21fe rigger with cc ice 240amp and leopard 3674 3270kv prop m440 b/s , 1st run after 2 1/2 min data logged was downloaded max current 147 esc temp98 motor temp111 batt temp 147 "no puff" let's go to a second 45min later with same setup max current 152 esc temp98 motor temp 115 , BATT TEMP over 200 deg melting heatshrink and wires , I contacted maxamps about it and sent them pix of the lipo right after it happen , NOW THIS LIPO IS RATED AT "75c" "150c" = 487.5 continues amps and my data log says I'm drawing not evens 1/4 of that max of course maxamps claim other wise blaming faulty system , numbers don't lie c rating on this batts ARE NOT UP TO PART FOR WHAT THE CLAIM TO BE.
detox
06-18-2012, 05:26 PM
Weak lipos will also cause your esc to burn.
Serpents811
06-18-2012, 05:28 PM
Detox , this was a new pack that was sent to me from maxamps
Brushless55
06-18-2012, 08:28 PM
not sure how they get away with such over rated claims on C ratings??
Serpents811
06-18-2012, 08:35 PM
They say 150c burst 75c continues which equals 487.5 continues amps thru 10gauge wire at that.
06-18-2012, 11:15 PM
The reality is that we consumers are at the mercy of the pack assemblers....just like in the round cell days they can print anything they want on a label. The only way to really get what you pay for is to use a pack assembler you can trust. Personally I think that anything over a claimed 45C continuous is BS....with today's tech anyway.
Serpents811
06-18-2012, 11:26 PM
I hear what your saying , there are a few claiming over 45c and how true it is , there is only one way to find out but I'm not going gambling my money on so claim high c rating packs that's for damn sure , I will be doing lots of research before I'll buy another pack again or at end of the day 1 gallon of 87 octane will give me plenty of run time for a day of fun
sanyijr
06-19-2012, 12:52 PM
As we americans have learned over the years.... It's all about how you define it.
Burst is what? 10 second? Maybe 15 seconds? If they tested for a whole 30 seconds continuously, perhaps continuous is........ 30 seconds? When it comes to lipo testing, continuous is not really defined. Common sense would lead you to believe that continuous would mean for the entire duration of a full discharge cycle, right? Maybe...
The other thing is I have 10 guage wire on my 4200mah 30C rated lipos and the wire is warmer than the cells or connecters. So I would think it is a compounded issue between wire size, cells and liars... Just my 1 cent
S
Serpents811
06-19-2012, 05:34 PM
S
That's my point c rating and material used ain't up to part , is like stuffing 140v from circuit board on a house thru 10 gauge wiring
Heaving Earth
06-19-2012, 05:37 PM
Maxcrap
Bigbore
07-11-2012, 10:19 AM
Did you see this thread? It seems you can predict the real c rating of you lipo by measuring the internal resistance of each cell of the battery.
http://www.rcgroups.com/forums/showthread.php?t=1577989
