View Full Version : 41" Fantasm Build AKA "DARK MATTER"
boddenboys4
06-18-2012, 03:26 PM
Ok I'm finally getting to post my build. Its my first build so be nice!! :Praying:
Well here is what I started with:
1 - 41" FG Fantasm hull from FCR
2 - 110mm Stingers W/Shafts
2 - 1717 Castle/Neu Motors
2 - FCR 240 amp 8s ESCs
4 - Large Water Outlets
2 - Thru the hull water inlets
1 - Antenna Mount
2 - Large Motor Mounts
1 - Scaled Rudder
1 - Vertical Servo Mount
1 - High Torque Servo
1 - 2.5 mm CF Plate
1 - 24" x 16" CK cloth (Black & Orange)
1 - Epoxy Resin
Then theres the other nick nacks
7923479235792367923779238
Ok I decided to do away with the 2 large motor mounts and make my own along with the cradle for the rear of the motors from the 2.5mm CF plate.
boddenboys4
06-18-2012, 03:39 PM
Having trouble uploading more Pics! Well I have completed the inlay and installed the stingers, rudder, motor mounts, servo mount with some minor modifications to let it set lower, water inlets and outlets, antenna mount.
I will try uploading more photos later. I also have videos but you will have to wait. Don't want to get ahead of the build. Like I did with the build itself, you will see later.
My plan is to complete the build, do all my testing and tweaking then I paint it. I think this is a good idea! Let you know later on!
boddenboys4
06-18-2012, 04:27 PM
792437924479245 There's the mounts. Ok time for you to see everything in and out so far!
7924679247
Ok that's a few more.
Then I got ahead of myself.
boddenboys4
06-18-2012, 04:31 PM
Thought this had went up: 79248
My youngest, he cant wait either!
boddenboys4
06-18-2012, 04:57 PM
First Run on 5s, Like I said, got a little excited:792527925379254
Now here's where I got a little too excited:
7925579256
That was the first run on 8s, little too windy.
boddenboys4
06-18-2012, 05:11 PM
Well after that run this was the outcome, Guess build and test then paint was a good idea!!!
7925779258
Thats what happens when you don't reinforce the transom.
So I added a CF plate and CK on the outside and inside of the transoms. Problem solved!!! So I'm down a counter rotating prop for now, waiting on my replacement.
79259 Plates for the inside. Didn't take pics of the outside ones sorry.
Bet your waiting for the video! Don't worry, soon get there!
Rumdog
06-18-2012, 05:50 PM
Nice build!
That looks like one gnarly wipe out. Sucks about the transom. Sound like you got her all fixed up though.
boddenboys4
06-18-2012, 05:54 PM
Ok, this is a week later. Enjoy!!!
792617926279263
This run was on a pair of borrowed Octura X450-3 Blade, they hadn't been balanced or sharpened.
Time for the video, the first is on 5s, the second is 8s.
Uploading videos, give me a bit.
boddenboys4
06-18-2012, 05:57 PM
It actually took it pretty good. I love the power it has. I cant decide on the paint scheme yet, but black and orange are the 2 main colours. Want a ripping/tearing look. Need an air brusher on Island!!!
boddenboys4
06-18-2012, 06:51 PM
Here is the video with her on 5s
http://youtu.be/R55a8-d5OZs
boddenboys4
06-18-2012, 06:54 PM
Here is the video with her on 8s
http://youtu.be/m-LxDSn_FFY
boddenboys4
06-18-2012, 07:04 PM
Here's the GPS
7929079291
It twisted the stingers in, gonna have to upgrade them.
Rumdog
06-19-2012, 10:29 AM
I'd bet that the unbalanced props caused the stinger failure. NEVER use raw props!
boddenboys4
06-19-2012, 01:37 PM
I balanced the props but now I need the stingers.
Brushless55
06-19-2012, 06:50 PM
specially at those rpms!
boddenboys4
06-26-2012, 03:42 PM
Well I did a 5s run on the balanced props and it ran great, but the stingers turned inward again and the inner bushings are lose in the stingers and the shafts have both pulled way back, time for the stinger upgrade.
RCKong
06-27-2012, 05:21 PM
WOW... I use these and have not had this happen. Is it the hull or the stingers ? Do you use a flexshaft or two piece square drive in them ?
If you use a flexshaft, you gotta have a little space in between the drive dog and the stinger for the cable to spool up. Even though there is very little cable, it will still move in an 1/8" under load.
boddenboys4
06-27-2012, 05:41 PM
I'm using the two piece square drive system. I left some play so that some movement is allowed. You think it may be the flex actually getting longer and forcing the solid part of the shaft back therefore pushing the inner bushing back? Should I pull the shaft into the collet more so it gives space for the square end to extend a little more and not bottom out on the solid shaft?
RCKong
06-27-2012, 06:17 PM
no the cable will shorten as it winds up. I got rid of the square drive,I had some problems with them after they were used a few times. I bought Hughey 3/16 cables and replaced them. They work flawlessly and are very well balanced.
boddenboys4
06-27-2012, 08:49 PM
Thanks I found them on Funrcboats.com. Out of stock at OFE. Should I go this way or get the drives that HOR has with the support brackets? They come with the shafts as well.
RCKong
06-28-2012, 11:35 PM
do you have any pics of the stingers mounted on the transom after they twisted ? I saw the top veiw but I'm wanting to see what failed or where it twisted.
Make-a-Wake
06-28-2012, 11:58 PM
On 8s that sucker is riding on the props!! Never seen a 1717 run on 8s..............big rpm's!! But, on the endbell the label says 45,000 rpms max which you are right at.
RCKong
06-29-2012, 12:02 AM
Yea thats alot of torque on them stingers
boddenboys4
06-29-2012, 12:46 AM
Its the bracket on top of the stingers that allows you to adjust the angle that have twisted a little, I will take a picture of it when I get the chance. The last run on 5s pulled them both in and the shafts back. But the props were balanced this time, it ran much better. Took on a 37" Genesis with a TP 4082-1200kv running on 10s and it had no trouble getting ahead.
boddenboys4
10-08-2012, 08:08 PM
Well, I have changed the stingers, running a pair from HOR, first run on new 648s and a lot lost a blade off one prop, didn't hit anything just torque I guess. It's a bullet out of the hole. Couldn't get to see what its really got, weather wasn't too good. No GPS either, next time for sure. Awesome tumble but took it well, think it went over at about 70 mph. Will take pics and videos next run.
ray schrauwen
10-08-2012, 09:29 PM
You run a heavy setup in that boat so you need those heavy duty Scale type stingers with the pod in the rear for support. I guess thats what you got from HOR...?
boddenboys4
10-10-2012, 12:06 AM
Yeah that's the drives I'm running now, I've been running 648s from FC, what prop would you recommend for top speed?
10-10-2012, 07:05 AM
...I've been running 648s from FC, what prop would you recommend for top speed?Before worrying about props, get your setup right. You can cut out several feet of wire between the ESC and the packs, do that first. Ditch the cheesy plugs and put on 6 to 8mm gold bullets. Shorten the motor wires - at that rpm you will get better ESC control of the motor by reducing inductance. Those changes will add speed and reliability while reducing heat and ripple current.
jcald2000
10-10-2012, 08:50 AM
2500KVA X 29 volts at 200 amp load on 6s 2p pack= 72,500 RPM.
But go with Jay's info, he has a lot of SAW experence.
10-10-2012, 12:06 PM
The Castle 1717 motors have a Kv of 1580, so on the water his 8S setup is closer to 41,000 rpm. The speed with x450 props on 8S should be around 80 mph, right were he was on the GPS. I'd use two-bladed counter-rotating props if it were me, and 3/16" cable - I think the OP is still using 0.150". Counter-rotating props require less rudder to hold the boat straight - less drag, higher speed.
rawsonreyes
10-11-2012, 01:17 AM
love when fluid speaks got two of his cats and i am sure he always can teach you something.:laugh:
boddenboys4
10-12-2012, 10:40 PM
Well I will start to work the wires first then take it for a run again. Been working on a couple other boats and time is limited. Doing some repair to the hull of my apparition with a 1520, got controls mixed up and had a run in with a concrete dock, the other is a Lynx with a 1515 4400 KV, will post build as soon as I start. Any recommendations for those two for top speed. It's go hard or go home so.....
bracka69
10-12-2012, 11:05 PM
Yep JB that's it. Go Hard or Go Home... Can't wait to get the lynx's up and going.
boddenboys4
10-15-2012, 09:44 PM
Soon Josh Soon! Gonna work templates tonight!
