View Full Version : Lipo placement in pursuit.
jamespl
06-15-2012, 09:33 AM
Taking my new pursuit out tomorrow for her maiden voyage after 3 attempts at stopping the water coming in! I'm running a XK-4074 2000kv T180 but is the battery tray the best place to put 2 2s lipos or does anyone know a better position? Maybe either side of the motor? Also does anyone know if the stock prop from HK is any good? If not I will try the x642.
06-15-2012, 11:30 AM
I run mine on the battery tray. (2) 4s lipo packs in parallel. And it works nicely.
urbs00007
06-15-2012, 01:37 PM
what happened to your 10 s rigger?
Diesel6401
06-15-2012, 02:21 PM
I run mine on the sides of the motor mount and run the esc & gps forward of the motor where the battery tray is.
I run a T180 & a Leopard 4074 2200kv. Runs amazing. As you can see different combo and placement still can work successfully.
Sent from my T-Mobile G2 using Tapatalk 2
jamespl
06-15-2012, 02:23 PM
I will have a play tomorrow if this great English summer time appears. See which works best.
06-15-2012, 03:43 PM
Just no time for the fun stuff.
jamespl
06-16-2012, 04:54 PM
Tryed it with the batteries on the tray and it was ok then either side of the motor and I think it ran better. This boat rocks. Just need a bit more speed out of it. I'd say it doing around 40mph
martin
06-16-2012, 05:55 PM
You want more prop with a 4074 motor, the stock prop on those is very lower in pitch around 1.2pitch ratio = only 2.03" pitch their also very small blade area to work on the stock 36mm can FSD motors. The x642 for example is 2.64" pitch.
osprey21
06-17-2012, 06:27 AM
I run a M445 prop on mine - 4074 2200kV, T180 and 5000mah batteries along side the motor - she runs close to 48mph.
http://www.youtube.com/watch?v=qX-9vzz4C9g&feature=player_embedded
jamespl
06-17-2012, 06:34 AM
I'm running the x642 at the mo. might Get the M445 and try that.
srislash
06-17-2012, 07:26 AM
Do you have a pic of your layout James?I'm going to start my build and am trying to suck up information.:tongue_smilie:
I have a 35" DF with the motor way forward but was thinking of putting this motor at the back.
jamespl
06-17-2012, 07:58 AM
79169Here you go
martin
06-17-2012, 09:53 AM
How are you holding the end of the motor where the clamp ring was to stop the motor from pivoting up & down. Thanks.
jamespl
06-17-2012, 09:57 AM
I'm not. Unfortunately it won fit because the screws on the end of the motor aren't counter sunk. It's done up tight though so its not going anywhere.
srislash
06-17-2012, 10:07 AM
So is this one of Steve's packages?
jamespl
06-17-2012, 10:19 AM
No this was from HK.
srislash
06-17-2012, 10:53 AM
No this was from HK.OK,thanks.I got mine from FC and I'm going to do a flood chamber and wetwell in it.It is a bare hull.
Diesel6401
06-18-2012, 01:06 PM
Got another Pursuit video. Batteries on the side of motor mount.
-_1r_fSjGhE
