View Full Version : proboat 1800kv
wht73
06-08-2012, 08:27 PM
Is this a 6 pole motor and if so what timing should it be set at?
can this motor handle 6s?
Diesel6401
06-08-2012, 08:39 PM
Yes its a 6pole, but more importantly its a "y" wind. Timing should be 7.5 - 15 although I would think 11.25 would be best. That's on a seaking esc, swordfish escs med timing should be just fine.
Change the motor/esc connectors to 5.5mm bullets the stock 3.5s wouldn't work, make sure your not using deans plugs 5.5mm or ec5 connectors. I'm personally NOT a fan of 1800kv motors and 6s, unloaded rpms are outside my comfort zone although being a 6 pole helps. Prop small, keep the runs limited to a few wot passes and keep in mind if it blows its your fault not a PB issue. Lot of guys run the motors way past what is recommended and get an attitude of something bad happens which isn't cool... in my book at least.
Sent from my T-Mobile G2 using Tapatalk 2
wht73
06-08-2012, 09:17 PM
Yeah it's a 180 hobbywing and I set it to 11.25. It already has 5.5mm bullets on it so that's done. I might just get 5s packs for it or more 7.4 with more ahr's.
There is a lot of room in there! (Mystic)
Diesel6401
06-10-2012, 05:04 PM
If you already have 2s lipos just get some 3s lipos same brand, mah and c rating as your 2s packs and run 5s.
wht73
06-10-2012, 06:11 PM
Thats ok to do? Which battery ends up with the positive lead to esc?
wht73
06-10-2012, 06:16 PM
Can this motor spin a x442 prop? I just ran it w/ 2p, 4s pacs and clocked 38.8mph with stock mtr and prop. 4s bats are to big though. Make the boat heavy also.
Diesel6401
Yup perfectly fine to do. Doesn't matter which lead ends where. Just make sure your wiring in series and not parallel.
Diesel6401
06-10-2012, 06:18 PM
Should spin just fine on 4s. Just drop down to 4s and not 4s2p. At speeds on stock motor on 4s your just carrying extra weight around.
wht73
06-10-2012, 06:21 PM
Yeah they are to bulky.
