View Full Version : * * Two Part Floatation Foam * *
Howard
06-08-2012, 06:16 AM
* NOW AVAILABLE * 2 Pound per Cubic foot Expanding Urethane Foam
2 - 4oz Bottles Part A & Part B
this is 1oz more then other sites offer for the same price. :w00t:
$15.50 Shipped USA Only - Paypal
http://i1058.photobucket.com/albums/t405/howardh12/IMG_4596.jpg
http://i1058.photobucket.com/albums/t405/howardh12/ebay%20stuff/IMG_4440.jpg
timjz
06-08-2012, 09:57 AM
How many cubic feet of foam will this kit make?
Howard
06-08-2012, 10:06 AM
This kit will do at least 1 boat possible 2. I don't know how many cubic feet. There are 2 4oz bottles in the kit
jimi911
06-08-2012, 10:51 AM
Cannot remember if I had a go at buying these before or not, but if you will ship to Canada I will take them.
Howard
06-08-2012, 11:00 AM
Yes you did :-) There's a problem with chemicals and customs. Sorry I can't ship there.
jimi911
06-08-2012, 11:05 AM
Haha ... thought so!
Chrisg81983
06-09-2012, 08:58 PM
How many cubic feet of foam will this kit make?This foam is a good quality will expand 20 to 30 times it original state so you do the math if it is a 2lb density one cubic foot can keep 60 plus pounds from sinking. What Howard is selling should do two small boats 36 inch or less. I buy a 16 pound kit two 1 gal containers and it last quite long. I probaly did 8 boats 36 to 48 inches and still have more than half left. Once you use this you will never use pool noodles again. It also adds a decent amount of strength to the hull as well, and does not fall out like pool noodles in a bad crash ( split )
06-09-2012, 11:26 PM
Two part foam I and others have used - like that below - will shrink in the heat and suck the deck in. Not all foams do that. What about this stuff, any long term trials in hot weather?
http://i47.tinypic.com/2mcvw45.jpg
Howard
06-10-2012, 05:10 PM
:smile: Thanks Chris for writing that information. That was nice of you and well appreciated
Howard
Howard
06-10-2012, 05:11 PM
Fluid why are you advertising something else on my thread??? That's pretty rude :angry:
Chrisg81983
06-10-2012, 05:41 PM
Hey Howard no problem ! I was really just telling people how great thisnstuff really is. @ jay I use foam for a few years now and never had it shrink or deform anything you just need a good grade foam that is approved by the us coast guard that is recommended for flotation devices. But if people are worried about that problem I have a good fix for it. You take the plastic tubes that go over flouresent light bulbs and cut to length of the sponson. Apply a lit layer of grease/ oil to the tube and pour some foam in, and while expanding put that tube in. The foam will surround the tube but stick to the bottom, side , and top of hull while leaving a void in the middle. Once the foam is almost set slide the plastic tube out. This leaves a void in the foam for air to get in and escape while still adding a lot of strength along with enough flotation. I can promise you will have no problems with shrinkage. Another thing to do is spray the whole inside of the hull down wi a 3 in 1 oil before you pour foam in. this will cause the foam not to stick to the hull. ( this will not effect how the foam expands ) Now if it does shrink it does not pull the hull with it, and now can be removed if ever desired.
JimClark
06-10-2012, 05:59 PM
If you read Jay's thread he is bashing the foam brand in his picture and is asking a valid question of the foam you are advertising re read it again
Howard
06-11-2012, 03:49 PM
Good info Chris, I should of done that to my Geico :confused2:
Howard
06-11-2012, 03:52 PM
I never had any problems with this foam and have been using it for years. With Chris's suggestions I think any shrinkage or expanding issues will be eliminated.
TheShaughnessy
06-11-2012, 03:54 PM
Yep. Fluid actually suggested steering clear of the foam he posted as it shrinks in the heat. He then goes on to ask a question regarding the foam you have.
Chrisg81983
06-11-2012, 04:55 PM
No problem ! I have about 12 hulls at the moment, and I used the 2 part foam in all of them. They are done all different ways some filled the ways I stated above. I also have some earilier hulls that are completely filled as well. Either way I never had any problems at all.
Howard
06-12-2012, 04:47 PM
Price drop $15.50 shipped to USA
proboatbill
06-14-2012, 06:12 PM
Howard I'll take a kit. PM me your PP account
Bill
proboatbill
06-16-2012, 01:12 AM
I forgot to ask, Do the instructions come with it?
Howard
06-16-2012, 06:11 AM
Yes instructions come with it :thumbup1:
Howard
06-18-2012, 11:56 AM
Bump
detox
06-18-2012, 12:27 PM
Fluid is right. I recently had a bad experience with this two part foam shrinking and collapsing deck on my Delta Force 33 mono. Had to remove all of it and repair. If you must use this stuff be sure to use release agent so when it does shrink (over time it will) it will not stick to insides and suck the bow inward. Now where's the Vaseline
Howard
06-18-2012, 12:50 PM
detox Please read ALL posts. Chris explains how to avoid this in detail ....
detox
06-18-2012, 01:35 PM
I did read all post. Vaseline should work as a release agent, but some type of spray would be easier to apply.
proboatbill
06-20-2012, 09:13 AM
Foam came yesturday, thanks for the quick shipping Howard :buttrock:
Billy
06-22-2012, 04:22 AM
I'll take a set Howard
skyhighdiver
06-22-2012, 03:06 PM
ill take one payayment sent
Howard
06-22-2012, 03:23 PM
Paul I need your address.
Thank you,
Howard
OttoSea
07-01-2012, 05:22 PM
I'll take a set. PM me with paypal info.
John
Howard
07-01-2012, 06:11 PM
Payment Received,
I'll ship them out tomorrow John, paypal should email you the tracking number
Thank you,
Howard :thumbup1:
Howard
08-01-2012, 05:03 AM
bump
