View Full Version : Does everyone else's screw that hold in the rudders and trim tabs not have bolts?
bdp1174
06-06-2012, 06:50 PM
Looked in the exploded views and they show nuts on the inside of hull to hold in the screws but mine does not have them.Wondering if it is supposed to be that way or if they forgot to put them on mine?
Please respond Grim or anyone else that has there boat.
here is a pic
78194
electric
06-06-2012, 07:15 PM
Looked in the exploded views and they show bolts on the inside of hull to hold in the screws but mine does not have them.Wondering if it is supposed to be that way or if they forgot to put them on mine?
here is a pic
78194
I am guessing you mean nuts? If that is the case it looks fine. Just like the SuperVee set up. Those plates you see are threaded and act as the Nut to hold everything on.
bdp1174
06-06-2012, 07:19 PM
Yes I meant nuts sorry.Ok so does yours look the same?Thanks again
Brandon
littledvl
06-06-2012, 07:36 PM
Mine is the same, I believe electric is correct, the plate is threaded.
bdp1174
06-06-2012, 07:52 PM
Ok thank you very much.I am gonna give mine a once over tonight and grease up the flex so I can hit the water with it hopefully tommorow.
electric
06-06-2012, 07:58 PM
Yeah, it is fine, do check each one to make sure they are snug. I just did mine a few minutes ago and all of them needed about a turn or so to tighten them up a bit. I might go run mine this evening also, trying to talk my son into braving the Texas heat.
Grimracer
06-07-2012, 03:34 PM
The replacement hardware sets come with tapped plates and nuts.
Grim
brushlessfreak
06-20-2012, 01:37 PM
Mine is the same way too,quick question anyone have severe chine walk i can barely keep it in the water?
