View Full Version : Painting geico
joker rc
06-06-2012, 07:16 AM
I started to paint mg , more pin striping yet:confused2: then clear,,i also blue printed ride pads no more hooks.
78158781597816078161
masonis1
06-06-2012, 08:42 AM
Looks nice. I'm about to do the same. Blueprint and repaint. Hope mine gets as nice as yours. Any tips
Sent from my SPH-D700 using Tapatalk 2
joker rc
06-06-2012, 09:01 AM
i used tamiya paints its pretty hard drying shell , much like gellcote deep blue met and mid blue with silver base and white base stripe on the hatch.
. ride pads use a rubber sanding block level them out with 240git ,dont rub to deep into the glass , you can now see the hooks .mask off were your filler runs over sides and fill with light weight car filler
carefully wipe over them filling the hooks .sand and refill any spots you missed or are not level ,finish with 400 git mask up and prime , sand 1200 git wetdry ,pant 1 +1/4 small tamiya tins did the white . great finish of that paint ,then lightly sand with 800 one way front to back and leave it like that ,a polished hull is slower in the water then a flat sanded finish .
masonis1
06-06-2012, 09:13 AM
Well I was planning on having the ride pads part of the design of the.boat as well if possible. I'm looking for a finished product like http://img.tapatalk.com/ad8d8f01-5767-e346.jpg
Ill have checkered on front tips and across the back hatch like on the real boat.my friends dad has.
joker rc
06-06-2012, 09:21 AM
well you will need a air brush to paint checkers on , or decals ,the black drop shadow on the blue will need air brush ,but can be done with rattle cans if your good , lol
masonis1
06-06-2012, 09:27 AM
For checkered zi was going to do.decals and the drop shadow.. I didn't even notice. Hah I could maybe pin strip.that. How can I.lay decals for checked
joker rc
06-06-2012, 09:36 AM
very tricky on geico hull the nose is rounded as you know ,so it will pinch the decal as it rolls over the side , need to do them it two or 3 segments and try your best to match them up !
masonis1
06-06-2012, 09:37 AM
So like cut a piece for each rounded piece
joker rc
06-06-2012, 09:43 AM
yeah i think you will need to depends on the decal play around with it see how you go .spray water with dish washing liquid on hull and sticker / decal so you can move it around .
masonis1
06-06-2012, 09:44 AM
Gotcha thanks again for the.tips.
