View Full Version : Best prop and expected speeds.
Curtis Canton
06-05-2012, 03:17 PM
I have a new mystic and would like to keep the electronics stock. What are the best prop options and what kinds of speed should i expect running 2 grim racer 4200mAh 7.4v batteries. Discharge rates are 30c continuous and 60 surge. They are 2 cell batteries.
Darin Jordan
06-05-2012, 03:57 PM
Do a search for this on the forum. There is a TON of information on this topic on here...
part time rc
06-13-2012, 03:11 PM
All stock Mystic with 2 5600 60C lipos and a Octura X447 prop. Slightly raise the strut. This thing lit up. Ck out video. I very happy now. Hope this helps. Not sure of speed but very stable. Will race good in stk class.
Scott Washam
http://www.youtube.com/watch?v=5Pt0pNGdwxA
Darin Jordan
06-13-2012, 03:17 PM
Scott Washam
I sure hope you have upgraded the contacts and keep an eye on runtimes with that setup... You are pulling around 85-90A average now through that 60A ESC, which will likely take it. The 3.5mm contacts, on the other hand, are likely already desoldering... Be careful!
detox
06-13-2012, 03:23 PM
The Motley Crew was running too wet (too tight)
part time rc
06-13-2012, 04:00 PM
Forgot to mention, no connectors at all. I direct soldered ESC wires to motor wires. My boat desoldered a connector on its maden run. Got rid of them then. Only two boats in video, but in oval racing with 4,5or 6 boats you very rarely hold it flat out all the time. So far motor temps and battery temps good. We ran a lot more laps in the video than what a normal race requires. Sure I have it on the upper limits, but thats what it took to to make it exciting. Thanks for the info. Thanks Darin.
Scott Washam
mayhem man
06-14-2012, 02:08 PM
Part time really has that mystic haulin with the setup he stated, very stable as well. Since then I hv loosened up the crew.
wht73
06-15-2012, 06:50 PM
I just ran my mystic with 2p4s 30/40 batts. Got about 4.5 min runtime and I also raised the stinger to be even withthe bottom of sponsons.
It went 42.3mph with a x442 SB prop. Temps on Hk esc and motor were perfect.
