View Full Version : Atomik 58 pics
forescott
06-01-2012, 11:23 PM
Just opened up the new ARC, and thought I would share some pics. Looks like atomic opened the box and inspected the boat prior to shipping. :thumbup1: Hardware looks pretty stout, motor mount looks nice although not sure if something like a leo 56mm motor or castle 2028 would fit between the rails without some major modifications to the stringers. Although running motors of that size should require some extra hull reinforcement anyway. Finish looks fantastic, nice scale details. Feels pretty light compared to my gas BJ55 without fuel. The motor does look awfully small inside the hull, but I can see how with a smaller-ish nicely sharpened and balanced prop, lighter weight, and keeping the strut up high enough to free up the prop a bit, this big hull could run adequately with the stock components. I'd feel a bit better if this package came with a little bigger esc like a t-180. I also would keep as little battery weight as possible in the hull(single 6s pack) in fear that loading up the hull with too much lipo could stress the motor/esc. Overall it looks good! Only time will tell how she holds up!
7781477815778167781777818
forescott
06-01-2012, 11:24 PM
7781977820778217782277823
forescott
06-01-2012, 11:25 PM
778247782577826
Rumdog
06-02-2012, 10:33 AM
The stuffing tube is Teflon?!
120 amp esc in a boat that size? wtf? i guess im overdoing all my stuff…. and yes, whats with the teflon stuffing tube?
forescott
06-02-2012, 12:47 PM
It actually looks like teflon over brass. Its feels solid, so I know its more than teflon. I'll have to take a closer look.
Plug in batteries...place in water.....hit the throttle..........come on......:drool:
Brushless55
06-04-2012, 12:38 PM
Let's see the vids! ;)
EricSchlaifer
06-04-2012, 12:43 PM
I've been thinking about this too. Let me know where your CG ends up with the battery in the stock location. I felt mine was running on the wet side. Now I'm thinking that (2) 3S packs in series is worth trying on a stock setup since it won't add tons of weight and will allow the batteries to be in the sponsons. Hopefully you get a chance to run the boat soon!
Brushless55
06-04-2012, 03:03 PM
so are you guys thinking this can't run 6s2p? :confused1:
if only one more pack makes it ride that wet or not have enough power.... :blink:
EricSchlaifer
06-04-2012, 03:18 PM
Not what I said at all. I'm sure it can run 6s2p, just wondering how noticable the extra weight will be. 2 packs will weigh in at almost 60 oz, 30oz of weight has got to affect the performance of any boat.
I have no idea what one more pack will do since I haven't tried it yet. What I was saying is that the stock battery location causes the CG to be about 1.5 inches forward of where I feel it should be. With a neutral strut angle I felt the hull ran a bit wet. I would like to know if Scott has the same experience when he runs his.
stadiumyamaha
06-04-2012, 03:22 PM
I would like to know if the paint work is any better than the p1 or c1. Clear and paint comes of with the tape the first time. Same or better?
EricSchlaifer
06-04-2012, 03:27 PM
I haven't had any issues with the paint on mine
Brushless55
06-04-2012, 04:14 PM
LOL
If running effects this boat like some ASSume, then maybe they should stick to cars and trucks..
This is a 55" hull and should have no issues running 6s2p, and with a motor change 10s2p+
And as far as this boats finish I sure hope its a home run vs my Gas KOS
That gell coat finish sucked... time will tell after a few runs on the water with this hull
And as I've noticed.... no videos from anyone on this hull, only the promo vids and a bunch of assuming
Chris Nicastro
07-02-2012, 01:10 PM
The gas hull w/o gas weighs about 16lbs and this version weighs 13lbs. So adding one more pack is not a big deal at all. The advantage is the ability to adjust the CG with the two packs in the sponsons. It is not hyper critical but it does make a difference and the boat will respond to the tuning.
The paint has been improved through the use of a new paint system and better prep work. If you have any issues with the hull please let us know. I'm constantly monitoring batches for consistency even after the sale.
rpedro
09-23-2012, 10:20 PM
So is anyone actually running this??? Would love some ACTUAL feedback...
EricSchlaifer
09-24-2012, 01:30 PM
I'm running it and love it! Its just too hot where I live to run right now so its on the shelf until fall.
rpedro
09-24-2012, 02:07 PM
awesome!!! any advice/feedback, etc would be great!!! maintenance advice etc, etc... thanks!!!
EricSchlaifer
09-24-2012, 02:11 PM
Are you new to FE boats? Its pretty much identical maintenance wise to any other boat. To lube the shaft you have to pull the motor mount which is sorta a pain but after you do it a few times it gets pretty easy. I started running two batteries in the sponsons. It seemed to make it handle better. The stock spot works fine though. It does take some getting used to due to the size of it. Be prepared to flip it a few times learning to do high speed turns! oh, and have at least a few batteries for it. My run times are usually only 4-7 minutes.
rpedro
09-24-2012, 04:30 PM
4-7 minutes??? yikes!!! will the 50c battery upgrade help??? what about two of either the 25c or 50c??? I am new to boats but not to RC... love the size of this beast...:) more buying it to cruise around, etc... racing it wasn't my plan anyway...
I can't wait to have this thing in my hands...:)
you got pics on how to wire the two batteries??? that would be great!!!
EricSchlaifer
09-24-2012, 05:33 PM
The 50C won't make a difference in run time, you would need more mah to get a longer runtime. But, to be honest I wouldn't want to run much longer than that before checking temps anyway. To wire up two batteres you would just parrelel them. Both red wires together and both black wires together. Or, you could run two 3s 7500 venom batteries in series. That would get you 6S with a longer run time...maybe 10-12 minutes. Every time I've taken the big cat out it draws a crowd!
rpedro
09-24-2012, 06:46 PM
Sounds really cool!!! Thanks for the advice/info... I look forward to getting mine next week...
rpedro
09-24-2012, 06:47 PM
How are you checking the temperature of the ESC/motor??? Thanks again...
forescott
01-05-2013, 06:44 PM
Finally ran this boat today for the first time. How many months ago did I start this thread?? Tried to run it yesterday but I couldnt get the transmitter and receiver to connect. Something funny was going on with the transmitter because the power light wouldnt turn on at first and after fiddling with the batteries got it to turn on but wouldnt connect. Thought maybe I grabbed the wrong transmitter from home because I have two of the same ones. It turns out it was the right one, so I swapped the stock radio for my trusty tactic. Everything checked out good. Went to my local pond this morning and ran it for about 4 minutes on a new zippy compact 6s 25c single pack. WOW, this boats really leaps up on plane and accelerates quickly! no gps but sure looks like the advertised 40mph, if not its real close.
When I pulled the hatch the esc was barely warm, but the motor felt pretty hot, I could hold my fingers against the can for about two seconds. Sorry for the lack of real data and video, but i was by myself this morning, and unprepared. I,m gonna try to get some good video and real data this week, but I plan on running this thing til something gives. My gut says the esc wont last too long running it on 6s, but the motor may fry if I run it too long without letting it cool down. Well see.
The rail spacing is only 3", and the stock motor mount has thick sides that will only allow for something like a castle 1717 cooling can to fit in between. A 56 mm motor will fit, but youd have to get a different mount. I wonder what kind of amps a 1717 on 6s would pull with a smaller than stock prop, say in the 47-48mm range?
lenny
01-05-2013, 09:55 PM
Hey, Good to hear.
The motor is a outrunner right ?
They run a lot hotter then inrunners.
srislash
01-05-2013, 10:21 PM
The rail spacing is only 3", and the stock motor mount has thick sides that will only allow for something like a castle 1717 cooling can to fit in between. A 56 mm motor will fit, but youd have to get a different mount. I wonder what kind of amps a 1717 on 6s would pull with a smaller than stock prop, say in the 47-48mm range?I would be well prepared for 200 amps with a 1717 and a 47mm prop.
forescott
01-06-2013, 10:39 AM
Hey, Good to hear.
Yes, the t-600 (1100kv)
lenny
01-06-2013, 11:20 AM
I forgot you bought one of those boats,
And I got the motor in good shape yesterday.
Great packing on it.
I still am running the stock 60a esc & outrunner 2000kv in my p1 kos mono,
The motor can handle 200f if not more.
Mlne in hot summer temps like 95f runs at 165f with a 5 minute run on 4s,
And on 5s I proped down to a x637 from the x440/3.
And the timing is set at 26.25,
Those motors like high timing on them and run cooler to.
lenny, can you find out from the guy who has this what id of atomik arc rails are that motor mount attaches too?
lenny
05-04-2013, 09:31 PM
I will try to find out that info.
hi, if i were to pick a leopard 5682 or 5692, what kv should I go for, they have 1000kv, 1090kv, 1360kv, 740kv, 540kv?? im thinking 8-9s max I would go.
lenny
05-04-2013, 11:50 PM
5692 730kv is good for 8s to 10s for sport running and having some good fun speeds,
And run times.
Or may be something else will work good to and be a little cheaper.
I need to do some digging on this one for more info.
Ttyl.
I think offshore's 56mm $18 motor mount will fit perfect in the 58in atomik cat!
lenny
05-05-2013, 11:57 PM
Hears some info for you,
It is all the same hull and just new paint and FE ready now.
http://forums.offshoreelectrics.com/showthread.php?3658-new-C1-Cat-on-the-block
http://forums.offshoreelectrics.com/showthread.php?37362-Another-Venom-55-quot-FE-conversion.-KOS-this-time!
http://forums.offshoreelectrics.com/showthread.php?33069-55-quot-Segad-Gas-to-FE-build...&highlight=segad
WhatRLaws4
07-20-2013, 12:15 AM
I have a converted KOS to FE. Im using the 5698 910kv, CC 200HV on 8s spinning a X452. Mid to high 50s. Much much faster than the stock ARC.
twissted
07-28-2013, 03:22 PM
you can buy the boat also with out batts., motor and esc. Cheep under 600.00 I think I my get one and try a duel motor setup. That would do a boat this size some justice.
Finest Racing
08-19-2013, 07:18 PM
I am trying to decide on a motor myself. I am running a 6s setup. I am running two 3s in series. I made a harness so I can try 4 batteries. I hope to try that out this Sunday. I would like to find a motor using the 3s batteries. I don't want to invest in more batteries. Any suggestions? Thanks
cgd2175
11-08-2013, 05:46 PM
just got my ARC 58, is amazing.
Any tips for me? I just put some positive angle to the strut and cavitates alot.
38mph with the GPS
Thanks
Chris
lenny
11-08-2013, 07:10 PM
What prop is on it ?
You should set the strut level with the sponsons bottom,
It can be done by putting the boat hull on a long flat table.
Than loosen the strut and have it touch the table and keep it level and than tighten it.
Now adjust your CG by moving the lipo packs forward or backward some.
Post some video's of it.
cgd2175
11-09-2013, 10:29 AM
Lenny, is the stock prop.
I started with that table level, and everything ok, but then wanted more speed and put +2mm in the strut and batteries backwards and I have the problem. I'll put it as the beginning and move the battery to the center and try if I can reach 40mph.
Then I'll put a 1400 T600 and see what happens.
This weekend im going to take some videos but is a very fun boat to run, also I have a Magnum 57, Arrow Shark Flying Dragon and a Hypersport 48 with clutch and water pump(all noisy).
lenny
11-09-2013, 11:10 AM
If your temps are good try propping up a little and run 1 minute and check temps,
And speeds.
If all good do it again longer.
cgd2175
11-09-2013, 12:25 PM
The smallest prop that I have to fit this prop shaft is my 70MM/16 3-Blade from Warehousehobbies , all my other props are 40 - 45mm, for my other FE (Revolt, Blackjack 29 and Spartan) and the other 2 blades for gas that I have from 70mm to 80mm.
http://www.whobbies.com/product.php?id=222
Im going to try it for 1 min to see what happens, Im going to change everything to 3/16 next month
lenny
11-09-2013, 12:45 PM
How big is the stock one ?
I would try the 45mm first,
70mm is a lot of prop so be very careful you do not smoke the setup with it.
cgd2175
11-09-2013, 12:58 PM
The stock one is 3 blade 53mm http://www.atomik-rc.com/Propeller-50mm-for-58-Electric-C1.html
The 45mm is not very small??
cgd2175
11-17-2013, 03:35 PM
I think I need to put more negative angle to the strut http://www.youtube.com/watch?v=ffcq3VfA3nQ
out of stock
04-28-2014, 10:56 PM
is there a drop in motor mount for this hull? lepard 5698
lenny
04-29-2014, 07:29 PM
Hi,:tiphat:
Post some pictures of your boat with the 5698 motor and jacket on it in the hull.
Did your boat come with the stock motor mount in it ?
Finest Racing
04-29-2014, 09:19 PM
Here are some pictures using the stock mount. It works great. No problems with a few runs.
114873
114874
I have a 57mm on the boat. I am hoping to try it this Friday. I used the stock side mounts, made a new front mount from aluminum.
out of stock
05-08-2014, 01:01 PM
that is simply awesome man thank u...
btw dons hobby shop never sent my hull..... hes had 7 business days to give me a tracking number so i disputed the charge and got my $ back. now i have a venom sagad 56 coming tomorrow.
now i need to find out what are the inside dimensions of the wood rails to determine what mount to get. Grrrrr!
thank you ever so much for the photos....
